07-06-2009 04:54 AM - edited 03-18-2019 10:27 AM
I am trying to dig around and locate a guide on using no user/pass for SIP outbound dial dialing. Inbound dialing is working good at the moment but when I try to dial outbound, I am trying to authorize, at least that's what my SIP provider is telling me. Is it possible in CME to accomplish this?
Thanks in advance.
07-06-2009 07:12 AM
You need to register to your SIP provider with user and password. Try to use something like:
sip-ua
credentials username xxx password yyy realm sip.provider.net
authentication username xxx password yyy
registrar dns:sip.provider.net expires 3600
sip-server dns:sip.provider.net
I assume you have dial-peers configured for outband traffic.
07-06-2009 07:57 AM
Thanks but I just got to the bottom of this. What I ended up doing was removing all of the SIP-UA info, that's only needed if you are passing a user/pass. My SIP provider is looking at IP only.
On my dial peers I had to force the sip-target to the dns:xx.x.x.com instead of using sip-register.
Thanks for passing along the info.
