02-26-2025 09:12 PM
02-26-2025 09:49 PM - edited 02-26-2025 09:56 PM
Other than adding it to the outbound invite with a SIP profile I don’t know how you could do that. The process that the router does this is per the defined SIP standards, so what your service provider is doing is outside of standard operation from what I know. With that I think it would be hard, if not impossible, to do this other than using a SIP profile that adds the outlined fields to the invite as one of the big use cases for SIP profiles is to handle interoperability between disparate systems.
If you post the entire SIP dialog in an attached text file it would be easier to help you out with crafting a SIP profile that could do this.
02-27-2025 12:20 PM
02-27-2025 12:57 PM
Thank you. One thing, a SIP dialogue is the entire SIP messages collection, not just one message.
02-27-2025 06:27 AM
Please read the following document, you can force the phone to send register request to CUBE first then the CUBE asked for authorization then the CUBE can send the first register message with authorization header.
02-27-2025 12:24 PM
Thank you @Mohamed H. Abdelmotaleb , my case is Cisco CUBE SIP TRUNK TO ITSP
