SIP based Cisco IP phones with Third party call control
sharada07
Do Cisco IP phones work with third party call Control agents eg Avaya Communication Manager S6800?
If so, should I provide the licenses also?
What licenses should I provide?
Steffen.Baier
Depending on your SIP Server you are using the Cisco Phones (example 7970) need the SIP Firmware and the Phone Settings need to be uploaded via a TFTP Server.
Steffen
The only Cisco phones that were meant to be supported with 3rd party call agents were the older phones - 7940,7960, etc.
The newer 7970,7941's,7962's etc were designed the same way, and the SIP stack was built for CUCM/CME.
You may find better support with the 40's/60's.
-nick
Appreciate your response.
Do I need to quote for third party licenses for the phones SW-SM-UL-7940 in this case?
Sharu
