11-26-2012 05:53 PM - edited 03-16-2019 02:24 PM
I have a CUE with three autoattendants whichs works great until you attempt to set a call forward for a cell phone to the external number of any of the autoattendants. I think the way to resolve this is with a translation but I haven't found anything that works.
I am placing the calls from 544544500 to a cell phone 5445441736 which is forwarded to the CUE at 4025551234. The autoattendant is on extension 391.
Debug out of the failed call:
061305: Nov 26 20:17:41.210: //93600/2A024DD98DFE/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x889741B0
State of The Call : STATE_DEAD
TCP Sockets Used : NO
Calling Number : 5445445500
Called Number : 5445441736
Source IP Address (Sig ): 192.168.2.2
Destn SIP Req Addr:Port : 172.16.1.1:0
Destn SIP Resp Addr:Port : 172.16.1.1:5060
Destination Name : 172.16.1.1
061306: Nov 26 20:17:41.210: //93600/2A024DD98DFE/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec : g711ulaw
Negotiated Codec Bytes : 160
Nego. Codec payload : 0 (tx), 0 (rx)
Negotiated Dtmf-relay : 6
Dtmf-relay Payload : 101 (tx), 101 (rx)
Source IP Address (Media): 192.168.2.2
Source IP Port (Media): 19298
Destn IP Address (Media): 172.16.1.1
Destn IP Port (Media): 62168
Orig Destn IP Address:Port (Media): [ - ]:0
061307: Nov 26 20:17:41.210: //93600/2A024DD98DFE/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC) : 16
Disconnect Cause (SIP) : 500
Debug out of a normal call:
061312: Nov 26 20:19:06.934: //93603/5D05610F8E03/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x88984F80
State of The Call : STATE_ACTIVE
Called Number : 391
Source IP Address (Sig ): 10.1.10.2
Destn SIP Req Addr:Port : 10.1.10.1:5060
Destn SIP Resp Addr:Port : 10.1.10.1:5060
Destination Name : 10.1.10.1
061313: Nov 26 20:19:06.934: //93603/5D05610F8E03/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Address (Media): 10.1.10.2
Source IP Port (Media): 16758
Destn IP Address (Media): 10.1.10.1
Destn IP Port (Media): 20952
061314: Nov 26 20:19:06.994: //93602/5D05610F8E03/SIP/Call/sipSPICallInfo:
Called Number : 4025551234
Destn SIP Req Addr:Port : 172.16.1.1:5060
061315: Nov 26 20:19:06.994: //93602/5D05610F8E03/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
Source IP Port (Media): 17344
Destn IP Port (Media): 62178
061316: Nov 26 20:19:13.770: //93602/5D05610F8E03/SIP/Call/sipSPICallInfo:
061317: Nov 26 20:19:13.770: //93602/5D05610F8E03/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
061318: Nov 26 20:19:13.770: //93602/5D05610F8E03/SIP/Call/sipSPICallInfo:
Disconnect Cause (SIP) : 200
061319: Nov 26 20:19:13.782: //93603/5D05610F8E03/SIP/Call/sipSPICallInfo:
Called Number : 391
061320: Nov 26 20:19:13.782: //93603/5D05610F8E03/SIP/Call/sipSPIMediaCallInfo:
Media Stream : 1
061321: Nov 26 20:19:13.782: //93603/5D05610F8E03/SIP/Call/sipSPICallInfo:
Voice Translations:
voice translation-rule 4
rule 1 /4025551238/ /390/
voice translation-rule 5
rule 1 /4025551235/ /391/
voice translation-rule 6
rule 1 /4025551236/ /390/
voice translation-rule 7
rule 1 /4025551237/ /392/
voice translation-rule 8
rule 1 /4025551234/ /391/
voice translation-rule 410
rule 1 /^9\(.......)\)$/ /419\1/
rule 2 /^9\(.*\)/ /\1/
rule 15 /^...$/ /4025551234/
voice translation-rule 411
rule 1 /^9\(.*\)/ /ABCD9\1/
voice translation-rule 412
rule 1 /^ABCD\(.*\)/ /\1/
voice translation-rule 422
rule 1 /^ABCD91900......./ //
rule 2 /^ABCD91976......./ //
rule 15 /^ABCD\(.*\)/ /\1/
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1111
rule 12 /^3\(..\)$/ /4025551237/
rule 13 /^2\(..\)$/ /4025551234/
rule 14 /^4\(..\)$/ /4025551238/
voice translation-rule 1112
rule 1 /^9/ //
voice translation-rule 2001
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
rule 1 /^91900......./ //
rule 2 /^91976......./ //
voice translation-profile Applied2-AA_Called_5
translate calling 3265
translate called 5
voice translation-profile AppliedLearning-AA_Called_8
translate called 8
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile Metaphor-AA_Called_4
translate called 4
voice translation-profile Metaphor2-AA_Called_6
translate called 6
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile PSTN_CallForwarding
translate redirect-target 410
translate redirect-called 410
voice translation-profile PSTN_Outgoing
voice translation-profile SIP_Incoming
translate called 411
voice translation-profile SIP_Passthrough
translate called 412
voice translation-profile SIP_Passthrough_CallBlocking
translate called 422
voice translation-profile TemplateMaps-AA_Called_7
translate called 7
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
Dial Peers:
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register confprof1
dspfarm profile 1 conference
description DO NOT MODIFY, active CCA conference profile - CCA2.0 codec711
codec g711alaw
codec g711ulaw
maximum conference-participants 16
maximum sessions 8
conference-join custom-cptone CCAjointone
conference-leave custom-cptone CCAleavetone
associate application SCCP
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
destination-pattern 441
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 442
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 443
port 0/0/2
no sip-register
dial-peer voice 4 pots
destination-pattern 444
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 390
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
destination-pattern 397
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 6 pots
description "catch all dial peer for BRI/PRI"
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 1031 voip
corlist outgoing call-national
description **CCA*North American-10-Digit*Long Distance**
translation-profile outgoing PSTN_Outgoing
preference 1
destination-pattern 91[2-9]..[2-9]......
session target sip-server
voice-class sip dtmf-relay force rtp-nte
dtmf-relay rtp-nte
codec g711ulaw
ip qos dscp cs5 media
ip qos dscp cs4 signaling
no vad
dial-peer voice 1032 voip
corlist outgoing call-international
description **CCA*North American-10-Digit*International**
preference 1
destination-pattern 9011T
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1033 voip
corlist outgoing call-local
description **CCA*North American-10-Digit*Service Numbers**
preference 1
destination-pattern 9[2-9]11
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1034 voip
corlist outgoing call-emergency
description **CCA*North American-10-Digit*Emergency**
translation-profile outgoing CALLER_ID_TRANSLATION_PROFILE
preference 1
destination-pattern 911
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1035 voip
preference 1
destination-pattern 9911
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1036 voip
corlist outgoing call-toll-free
description **CCA*North American-10-Digit*Toll-Free**
preference 1
destination-pattern 91855.......
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1037 voip
preference 1
destination-pattern 91866.......
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1038 voip
preference 1
destination-pattern 91877.......
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1039 voip
preference 1
destination-pattern 91888.......
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1040 voip
preference 1
destination-pattern 91800.......
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1041 voip
description **CCA*North American-10-Digit*10-Digit Local**
preference 1
destination-pattern 9[2-9]..[2-9]......
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2006 voip
description ** cue auto attendant2 number **
destination-pattern 391
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 2007 voip
description ** cue auto attendant3 number **
destination-pattern 392
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1000 voip
permission term
description ** Incoming call from SIP trunk **
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1001 voip
description ** star code to SIP trunk **
destination-pattern *..
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 1003 voip
description ** Passthrough Inbound Calls for PSTN from CUE **
translation-profile incoming SIP_Passthrough
b2bua
incoming called-number ABCDT
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1005 voip
description ** Passthrough Inbound Calls for MWI from CUE **
b2bua
incoming called-number A80T
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 1009 voip
description ** Passthrough Inbound Calls for Internal Extensions from CUE **
b2bua
incoming called-number ^...$
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 3000 voip
description VERBS-AA
translation-profile incoming VERBS-AA_Called_4
incoming called-number 4025551238
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3001 voip
description NINJA2-AA
translation-profile incoming NINJA2-AA_Called_5
incoming called-number 4025551235
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3002 voip
description VERBS2-AA
translation-profile incoming VERBS2-AA_Called_6
incoming called-number 4025551236
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3003 voip
description CrazyTeds-AA
translation-profile incoming CrazyTeds-AA_Called_7
incoming called-number 4025551237
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 3004 voip
description ACME-AA
translation-profile incoming ACME-AA_Called_8
incoming called-number 4025551234
voice-class codec 1
dtmf-relay rtp-nte
no vad
sccp
sccp ccm group 1
codec g711alaw
codec g711ulaw
maximum sessions 8
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
member internal
member emergency
member internal
member local
member emergency
member toll-free
member internal
member local
member local-plus
member emergency
member toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
member internal
member local
member local-plus
member national
member emergency
member toll-free
port 0/0/0
no sip-register
port 0/0/1
no sip-register
port 0/0/2
no sip-register
port 0/0/3
no sip-register
port 0/4/0
no sip-register
port 0/1/0
port 0/1/1
port 0/1/2
port 0/1/3
port 0/1/0
no sip-register
port 0/1/1
no sip-register
port 0/1/2
no sip-register
port 0/1/3
no sip-register
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
direct-inward-dial
preference 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
preference 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
preference 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
preference 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
preference 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
preference 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
preference 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
preference 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
preference 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
preference 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
preference 1
dtmf-relay rtp-nte
codec g711ulaw
no vad
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
permission term
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
b2bua
dtmf-relay rtp-nte
codec g711ulaw
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
description ACME-AA
voice-class codec 1
dtmf-relay rtp-nte
no vad
