Sip call timeout after 180 ring message
We need to configure a dialpeer which identifiy ring no answer /timeout after ring and after this get call back to select another dialpeer to send this call.
We know about some timeout before call is made, but in this, we need a way to monitore a sip call with invite, trying and ringing messages receveid and after we get 180 ring message timeout, we get back this call and try to send to second dialpeer.
Customer has asterix doing this in CC enviroment for external contacts and we need to do same actions using Cisco Router
bsrohan
Configuring preference levels for dial-peers can help in your requirement. Please check the below link for section "Number String Dial-Peer Hunting"
https://www.cisco.com/c/en/us/support/docs/voice/ip-telephony-voice-over-ip-voip/211306-In-Depth-Explanation-of-Cisco-IOS-and-IO.html#anc7
- Rohan
Configuring preference levels for dial-peers can help in your requirement. Please check the below link for section "Number String Dial-Peer Hunting",
- Rohan
If this helps, please rate !
