SIP Calls over MPLS - Packet Sniffer Issue
Topology:
IP Phone => SCCP => CUCM => SIP => CUBE => Service provider
Issue:
I tried to collect packet trace from both port of CUBE to troubleshoot and identify choppy audio. Unfortunately the packets received and sent are over MPLS due to which i am not even able to see RTP Stream (not even SIP Streaming). Calls are sucessfull with G729 Codecs.
How can i decode and play G729 codec over MPLS network. My network team also use to say VRF. not sure if VRF network and MPLS network are the same.
Cisco Forum Document i reffered was https://supportforums.cisco.com/document/29616/utilizing-new-packet-capture-feature
It says we cannot use it for MPLS network. Are there any alternatives..
Please help..
2 Accepted Solutions
have you tried the steps given in the below link?
https://supportforums.cisco.com/docs/DOC-36782
//Suresh Please rate all the useful posts.
The create profile is not a command, its just telling to create the packet capture profile..
Here is a step by step guide
NB: you need to configure the packet capture before you start the call. Once the call ends, after transfer is completed, stop the capture
The int fa0/0 should be the interface that connects to ITSP..so change it to whatever interface that is.
1. Configure capture profile
               ip traffic-export profile TAC mode capture
               bidirectional
               interface fa0/0  ----> Interface which routes the traffic
               ip traffic-export apply TAC 99999999
2. Capture traffic with these exec (enable) level commands
Note: The exec cmds don’t appear until a profile has been configured
router#traffic-export interface fa0/0 clear
router#traffic-export interface fa0/0 start
router#traffic-export interface fa0/0 stop
3. Export the pcap file to a server
router#traffic-export interface fa0/0 copy ftp://x.x.x.x/capture.pcap
Please rate all useful posts
Hi Suresh,
I had to stop at line 1 in that document as that command did not exists..
"create profile"
IOS is 15.2(4)M5
               bidirectional
