Sip CANCEL message sent too soon
dan.letkeman
Level 4
Level 4
My sip provider is saying that my router is sending the cancel request too soon and not waiting long enouph for there system to respond.  Here are the logs from the router when I try to make a call:
Jul 14 23:13:02.800: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 183 Session Progress
Via: SIP/2.0/UDP 211.211.211.1:5060;branch=z9hG4bKE41B1;received=211.211.211.1
From: <sip:2225551234@did.voip.les.net>;tag=E2B693A4-C21
To: <sip:12225551234@did.voip.les.net>;tag=as7d976ff6
Call-ID: A5FA4E39-ADA511E0-B0AE8F35-C53231D0@211.211.211.1
CSeq: 101 INVITE
User-Agent: LES.NET.VoIP
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY
Contact: <sip:12225551234@64.34.181.47>
Content-Type: application/sdp
Content-Length: 216
v=0
o=root 19801 19801 IN IP4 64.34.181.47
s=session
c=IN IP4 64.34.181.47
t=0 0
m=audio 13480 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
Jul 14 23:13:02.804: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CANCEL sip:12225551234@did.voip.les.net:5060 SIP/2.0
Date: Thu, 14 Jul 2011 23:12:58 GMT
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1310685182
Reason: Q.850;cause=127
Content-Length: 0
Jul 14 23:13:02.856: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 487 Request Terminated
CSeq: 101 INVITE
Content-Length: 0
Jul 14 23:13:02.856: //18945/002829CE3800/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x31670E60
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 2225551234
Called Number            : 12225551234
Source IP Address (Sig  ): 211.211.211.1
Destn SIP Req Addr:Port  : 64.34.181.47:5060
Destn SIP Resp Addr:Port : 64.34.181.47:5060
Destination Name         : did.voip.les.net
Jul 14 23:13:02.860: //18945/002829CE3800/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : g711ulaw
Negotiated Codec Bytes   : 160
Nego. Codec payload      : 0 (tx), 0 (rx)
Negotiated Dtmf-relay    : 6
Dtmf-relay Payload       : 101 (tx), 101 (rx)
Source IP Address (Media): 211.211.211.1
Source IP Port    (Media): 0
Destn  IP Address (Media): 64.34.181.47
Destn  IP Port    (Media): 13480
Orig Destn IP Address:Port (Media): [ - ]:0
Jul 14 23:13:02.860: //18945/002829CE3800/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 127
Disconnect Cause (SIP)   : 487
Jul 14 23:13:02.860: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
Sent:
vr#ACK sip:12225551234@did.voip.les.net:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Allow-Events: telephone-event
Content-Length: 0
Is there a timer command that I need to configure to fix this?
________________________________________________________________________
My config:
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback none
h323
  h225 timeout setup 3
sip
  redirect contact order best-match
sip-ua
credentials username 111111 password 7 123456 realm did.voip.les.net
authentication username 111111 password 7 123456 realm did.voip.les.net
no remote-party-id
retry invite 4
retry response 3
retry bye 2
retry cancel 2
retry register 5
timers register 250
registrar dns:did.voip.les.net expires 3600
sip-server dns:did.voip.les.net
no suspend-resume
The interesting thing is that using this same exact configuration on a different router works fine.....The one that works is a 2811 and the one that doesn't work is a 2921
Currently running 15.0(1)M6 on the 2921
Running 15.0(1)M5) on the 2811
Dan.
5 Replies 5
linuxchild
try to make  debug ccsip error , you may have more info
vr#debug ccsip error
SIP Call error tracing is enabled
vr#
Jul 15 14:55:14.286: //37/00243E700300/SIP/Error/sipSPI_ipip_set_history_info_header:
Not SIP2SIP mode
Jul 15 14:55:14.294: //37/00243E700300/SIP/Error/sipSPI_ipip_set_history_info_header:
Not SIP2SIP mode
Jul 15 14:55:14.294: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:12225551234@did.voip.les.net:5060 SIP/2.0
Via: SIP/2.0/UDP 211.211.211.211:5060;branch=z9hG4bK2FA20
From: <>2043248910@did.voip.les.net>;tag=33524D8-1DAE
To: <>12225551234@did.voip.les.net>
Date: Fri, 15 Jul 2011 14:55:14 GMT
Call-ID: 47D0B7B5-AE2911E0-801DAA89-456D6B@211.211.211.211
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0002375280-3511943650-0050394625-0168544441
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE,
vr#OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1310741714
Contact: <2043248910>
Call-Info: <211.211.211.211:5060>;method="NOTIFY;Event=telephone-event;Duration=2000
Expires: 180
Content-Length: 0
Jul 15 14:55:14.362: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 211.211.211.211:5060;branch=z9hG4bK2FA20;received=211.211.211.211
CSeq: 101 INVITE
Contact: <12225551234>
Content-Length: 0
Jul 15 14:55:18.438: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
To: <>12225551234@did.voip.les.net>;tag=as15d7502b
CSeq: 101 INVITE
Content-Length: 216
v=0
o=root 14962 14962 IN IP4 64.34.181.47
s=session
t=0 0
m=audio 15300 RTP/AVP 0 101
a=fmtp:101 0-16
Jul 15 14:55:18.438: //37/00243E700300/SIP/Error/sipSPICheckReliableProvStringtag: Un
able to access supported header values
SIP: Attribute mid, level 1 instance 1 not found.
Jul 15 14:55:18.442: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1310741718
Content-Length: 0
Jul 15 14:55:18.510: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 101 INVITE
Content-Length: 0
Jul 15 14:55:18.510: //-1/xxxxxxxxxxxx/SIP/Error/sipSPIRemoveBranchName: invalid ccb,
bName or branch list for sipSPIRemoveB
Received:
SIP/2.0 200 OK
CSeq: 101 CANCEL
Content-Length: 0
Jul 15 14:55:18.510: //37/00243E700300/SIP/Error/act_dying_new_message: Received unex
pected response, dropping it
Sent:
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Looks like about the same information....
Hard to say , but I have no clue , do you have a firwall in the middel , I would check the log to see if any thing is blocked
I'm getting this same issue, did you find a solution?
MGCP, CCNA, CCNA Voice certified
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Yes, I forgot to add this dial-peer
dial-peer voice 901 voip
incoming called-number 8.T
dtmf-relay h245-alphanumeric
codec g711ulaw
no vad
I used 8 as the prefix for my sip trunk calls and the router that was terminating the sip trunk didn't know what to do with the call, after I added this it worked, but I don't remember the reason at the moment.
