I have created a sip connection to service provider. System confirms that SIP is active via display of
SIP Service is up message
I then issue command debug ccsip messages to below output
Mar 2 01:25:36.985: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:sip1.exetel.com.au:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK77F128D
From: "1002" <sip:1002@sip1.exetel.com.au>;tag=5548D44-1AB4
To: "1002" <sip:1002@sip1.exetel.com.au>
Date: Sat, 02 Mar 2002 01:25:36 GMT
Call-ID: AE8C25C9-2BE311D6-8004BD66-4265DFE7
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 10
Timestamp: 1015032336
CSeq: 639 REGISTER
Contact: <sip:1002@192.168.3.1:5060>
Expires: 3600
Content-Length: 0
show ip sockets
cme_router#sh ip sockets
Proto Remote Port Local Port In Out Stat TTY OutputIF
17 0.0.0.0 0 192.168.2.2 2517 0 0 1 0
17 192.168.2.3 68 192.168.0.12 67 0 0 2211 0
17 --listen-- 192.168.0.12 123 0 0 1 0
17 58.96.1.2 5060 192.168.0.12 51554 0 0 205 0
17 0.0.0.0 0 192.168.3.1 5060 0 0 241 0
17 58.96.1.2 5060 192.168.3.1 51279 0 0 205 0
cme_router#
cme_router#sh sip-ua status
SIP User Agent Status
SIP User Agent for UDP : ENABLED
SIP User Agent for TCP : ENABLED
SIP User Agent bind status(signaling): ENABLED 192.168.3.1
SIP User Agent bind status(media): ENABLED 192.168.3.1
SIP early-media for 180 responses with SDP: ENABLED
SIP max-forwards : 10
SIP DNS SRV version: 2 (rfc 2782)
NAT Settings for the SIP-UA
Role in SDP: NONE
Check media source packets: DISABLED
Maximum duration for a telephone-event in NOTIFYs: 2000 ms
SIP support for ISDN SUSPEND/RESUME: ENABLED
Redirection (3xx) message handling: ENABLED
Reason Header will override Response/Request Codes: DISABLED
SDP application configuration:
Version line (v=) required
Owner line (o=) required
Timespec line (t=) required
Media supported: audio image
Network types supported: IN
Address types supported: IP4
Transport types supported: RTP/AVP udptl
But when I try to confirm registering of sip I get this
cme_router#sh sip-ua register status
Line peer expires(sec) registered
0300 20001 0 no
1002 20002 114 no
192.168.0.12 1 30 no
cme_router#
Can someone please explain this to me thanks
