SIP Early Offer vs Delayed Offer
francisg
ITSP -- CUBE -- CUCM -- SIP/SCCP IP Phone
ITSP -- CUBE -- CUCM -- MGCP/QSIG to turret System
ITSP -- CUBE -- CUCM -- SIP to another Turret system
What is the proper setup for configuring a my SIP trunks?
The CUBE is configured for EO going to the ITSP and CUCM
CUCM is configured to use DO via the SIP profile.
CUCM SIP trunk also has "MTP required" unchecked.
What is the difference between setting the SIP Profile "early offer support for voice and video calls" to Best Effort (do not insert MTP) and Mandatory (insert MTP if needed)?
R0g22
It really depends how do you want things to be setup. ITSP's more often than not require EO therefore CUBE's are configured for EO. Do can setup CUCM to do EO if you are running into any restriction on the CUBE that might prevent it from doing a DO to EO interop.
For your other question -
1. Best effort - CUCM will minimize the MTP allocation and try it's best to not allocate one when initiating a EO SIP call.
2. Mandatory - CUCM will always insert/invoke an MTP to initiate a EO sip call.
