SIP Extension service
I am having Cisco Unified CM Administration call manager (System version: 7.1.3.10000-11).
Can we enable SIP Extension Service in the same? And do we need separate license for the same?
Thanks.
j.huizinga
Level 6
Level 6
SIP extension service?
What do you mean?
I mean to say ... we have CISCO CUCM  & CISCO IP Phones. Now can I also use NON CISCO IP Phones?
yes
java
if this helps, please rate
Jaime Valencia
If you mean if you can add SIP devices, yes, you can, given they are available from the drop-down, or use a 3rd party.
Any device requires DLUs
java
