10-23-2012 10:47 AM - edited 03-16-2019 01:50 PM
Is it possible to connect a cisco gateway to the PSTN using a E1/T1 interface and connect to the callmanager using SIP
All I can see config for is H.323 and MGCP
ian
Solved! Go to Solution.
10-23-2012 11:07 AM
Ian,
Sure you can have a dial-peer voice voip with seesion protocol sipv2 pointing to the CUCM server.
On the CUCM side you would create a SIP Trunk pointing to the GW IP Address.
10-23-2012 11:07 AM
Ian,
10-23-2012 11:24 AM
thanks - whats the feature comparison like for ISDN and SIP vs ISDN and MGCP?
10-23-2012 11:51 AM
Ian,
I don't have a side by side comparison for SIP vs MGCP, but from my personal experience I would stick to MGCP.
SIP has pitfalls with MTP in some scenarios, unless there's a company policy favoring SIP over other protocols MGCP works quite well.
