T1 PRI D Channel
mike-greene
Level 4
Level 4
Is it normal for calls to use channel 23 as a B channel?  I've never seen this before..
        Bearer Capability i = 0x8090A2
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA98397
                Exclusive, Channel 23
        Calling Party Number i = 0x2180, 'xxxxxxxxxx'
                Plan:ISDN, Type:National
        Called Party Number i = 0x80, 'xxxxxxxxxx'
                Plan:Unknown, Type:Unknown
Global ISDN Switchtype = primary-ni
ISDN Serial0/0/0:23 interface
        dsl 0, interface ISDN Switchtype = primary-ni
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        6 Active Layer 3 Call(s)
        CCB:callid=8FDB, sapi=0, ces=0, B-chan=21, calltype=VOICE
        CCB:callid=8FDC, sapi=0, ces=0, B-chan=20, calltype=VOICE
        CCB:callid=8FE1, sapi=0, ces=0, B-chan=22, calltype=VOICE
        CCB:callid=9013, sapi=0, ces=0, B-chan=23, calltype=VOICE
        CCB:callid=9014, sapi=0, ces=0, B-chan=18, calltype=VOICE
        CCB:callid=EA9, sapi=0, ces=0, B-chan=1, calltype=VOICE
    Active dsl 0 CCBs = 6
    The Free Channel Mask:  0x8005FFFE
    Number of L2 Discards = 0, L2 Session ID = 229
    Total Allocated ISDN CCBs = 6
Thanks.
2 Accepted Solutions
Rob Huffman
Hi Mike,
Yes, a full PRI would have 23-B + 1-D channels so channel 23 would
carry voice traffic
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
Mike,
Timeslots and channels on the GW are not cardinal numbers (0-23) the gateway actualli account for them as (1-24) for an akward reason.
It's normal to see calls comming into channel 23, 24 would be a different story.
You can confirm this with your
pri-group timeslots 1-23, 24 command
Rob Huffman
Hi Mike,
carry voice traffic
Cheers!
Rob
Thanks Rob,
I was always under the impression that channels 0-22 would be the 23 B channels and channel 23 would be the D channel for the PRI since is up/up and spoofing.
Mike
Mike,
Rob/Robert,
Thanks for the clarification.
Mike
