SIP Gateway protocol Integration with CM8.6
rmrahman0302
I am going to deploy Call Manager 8.6. and planning to use SIP as a gateway protocol. Is there any pros and cons to use SIP instead of H323 protocol and also I tried to find the configuration guide to integrate with CM 8.6. Anybody has any idea where I can find the proper document. Will appreciate your expert help.
Thanks.
Chris Deren
Either one is perfectly fine as both share similar feature sets and are peer-to-peer protocols requiring dial-peers.  I've done both successfully.
HTH,
Chris
Hi Chris,
Thanks for your reply. Is there any document which I can a take a look for the deployment?
Thanks.
