SIP incoming/outgoing call failed. Reason: Q.850;cause=28;text="address incomplete"
mohsin majeed
Level 2
Level 2
Hi Experts,
I am facing an issue where i am going to add a new sip range on the same physical trunk.
We already had two ranges 2835XXX, 2438XXX and there is one more new range need to be added.
Scenario is Phones(SIP/SCCP) ----> CUCM ---siptrunk---> UBE ---sip---> ITSP
Newly range is 4945XXX. Necessary configuration is done CM and UBE.
Outgoing call failed with "Call cannot be complete as dialed, this is the recording"
Incoming call failed with a message "not a valid number"
Calling number 4945001
Called number 0501029946
debug ccsip messages
debug voip ccapi inout
sh run
are attached.
please help
Mohsin Majeed
5 Replies 5
Nadeem Ahmed
Hi Mohsin,
By checking the logs looks like we are sending wrong/incomplete number to provider thats why they are sending 484.
Here you receive 484 from provider.
077838: Sep  1 19:42:50.691: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 484 Address Incomplete
Via: SIP/2.0/UDP 10.66.7.126:5060;branch=z9hG4bK7AAC52192
Record-Route: <sip:10.200.7.157:5060;transport=udp;lr>
Call-ID: 76BCDCD9-501811E5-8181A4F2-85CD1AE5@10.66.7.126
From: "Test11"<sip:4945001@10.66.7.126>;tag=42F41C24-873
To: <sip:0501029946@10.200.7.157>;tag=sbc0802auud4e7b
CSeq: 101 INVITE
Warning: 399 - "SoftX3000 R601-CCU Rel POS:[3103] Release from CR"
Content-Length: 0
077839: Sep  1 19:42:50.695: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 172.16.200.20:5060;branch=z9hG4bK24638b7f7e7c
From: "Test11" <sip:4945001@172.16.200.20>;tag=173064~7a4acf75-5f09-4773-8466-a6fba898a872-46739733
To: <sip:00501029946@10.1.0.4>;tag=42F41C6C-2037
Date: Tue, 01 Sep 2015 19:42:50 GMT
Call-ID: 9f901e80-5e51ffba-14df9-14c810ac@172.16.200.20
CSeq: 101 INVITE
Allow-Events: kpml, telephone-event
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Subsequently CUBE is sending 484 to CUCM.This 484 message was sent to CUCM which caused the CUCM ANN prompt to play to the ip phone
user.
Calling party number:4945001
Called party number:00501029946
Is this the correct calling and called party if not you can translate on GW and then send what exactly provider is looking for. If everything is correct then probably you can check with your provider on this.
But looks its a issue with the number.
Br,
nadeem
Br, Nadeem Please rate all useful post.
Kunal Narula
Hi Mohsin,
As the cause value suggest 484 Address incomplete is seen when called number routing is not configured at ITSP/Telco end. Can you verify if called /calling number routing is configured for the digits we are sending to them?
Also verify what cause value does PSTN see at their end? Is it 47? if so then verify codec configured at their end?
Incase it is different then we need to configure Xcoder/mtp?
Snippet from logs:
INVITE sip:00501029946@10.1.0.4:5060 SIP/2.0
Supported: timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM9.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:172.16.200.20:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Cisco-Guid: 2677022336-0000065536-0000085445-0348655788
Session-Expires:  1800
P-Asserted-Identity: "Test11" <sip:4945001@172.16.200.20>
Remote-Party-ID: "Test11" <sip:4945001@172.16.200.20>;party=calling;screen=yes;privacy=off
Contact: <sip:4945001@172.16.200.20:5060;transport=tcp>
Max-Forwards: 70
Content-Type: application/sdp
Content-Length: 423
v=0
o=CiscoSystemsCCM-SIP 173064 1 IN IP4 172.16.200.20
s=SIP Call
c=IN IP4 172.16.3.158
b=TIAS:64000
b=AS:64
t=0 0
m=audio 19490 RTP/AVP 8 9 18 0 116 101
a=rtpmap:8 PCMA/8000
a=ptime:20
a=rtpmap:9 G722/8000
a=ptime:20
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:116 iLBC/8000
a=ptime:20
a=maxptime:60
a=fmtp:116 mode=20
a=rtpmap:18 G729/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Outgoing dial-peer configuration:
dial-peer voice 802 voip
 description ** SIP TO STC **
 translation-profile outgoing OUT
 destination-pattern .T
 rtp payload-type cisco-codec-fax-ack 98
 rtp payload-type nte 97
 session protocol sipv2
 session target ipv4:10.200.7.157:5060
 session transport udp
 dtmf-relay sip-notify rtp-nte sip-kpml
 codec g711alaw
Incoming translation rule/dial-peer
dial-peer voice 202 voip
 description ** SIP INCOMING FROM STC **
 translation-profile incoming SIPINCOMING283
 translation-profile outgoing REDIAL283
 preference 1
 destination-pattern 5...
 session target ipv4:172.16.200.13
 incoming called-number 2835...$
 voice-class codec 1
 no vad
dial-peer voice 301 voip
 translation-profile incoming SIPINCOMING243
 translation-profile outgoing REDIAL243
 destination-pattern 8...
 session target ipv4:172.16.200.20
 incoming called-number 2438...$
 voice-class codec 1
 voice-class sip dtmf-relay force rtp-nte
 no vad
voice translation-profile SIPINCOMING243
 translate called 152
voice translation-rule 152
 rule 1 /^2438/ /8/
 rule 2 /^12438/ /8/
 rule 3 /^112438/ /8/
 rule 4 /^0112438/ /8/
voice translation-profile SIPINCOMING283
 translate called 52
voice translation-rule 52
 rule 1 /^2835/ /5/
 rule 2 /^12835/ /5/
 rule 3 /^112835/ /5/
 rule 4 /^0112835/ /5/
I also see a significant change between configuration of 2835XXX/ 2438XXX and 4945XXX. In case of later, you don't have a customized incoming dial-peer that translation rule reducing seven digit number to 4 digits. Is there a change in calling number requirement from telco?
Thanks!
Kunal
Please rate all helpful post
Your ITSP is rejecting the call and not accepting the called number which you are sending.
1. Make sure that you are sending the called number in the expected format as needed by provider.
2. Make sure that the provider isn't having problem in routing calls from your SIP trunk
Wilson Samuel
Level 7
Level 7
Just adding to others point. As per the observations from the debugs it appears that:
1. Calling Number is being sent as 494-5001
2. Called Number is 050-102-9946
May be the STC is expecting Calling Number  in the National Number, hence please try sending the Calling Number as 01X-494-5001 ?
mohsin majeed
Level 2
Level 2
Thank you all for your valuable information. I will visit the site and will test as suggest by you all. I will keep posting updates.
Thanks you so much
