sip multi-party ad-hoc conference issue
changcheng Guo
In my UC Demo, the sccp phone can create  over 3 parties ad-hoc conference using DSP (inclue sccp phone),but the sip phone only create 3 parties (include sccp phone).
My test device :  ISR2911 with PVDM3-32, CME 9.0 , 2*9951-camera, 1*7911(sip),2*CIPC,1*7940(sccp) ,1*Catalyst 2960-24PS
Below is my CME configuration,pls help me check it ,thanks a lot!
voice-card 0
voice-service dsp-reservation 50
dspfarm
dsp services dspfarm
voice service voip
no notify redirect ip2ip
clid network-provided
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  registrar server
voice register global
mode cme
source-address 172.16.200.1 port 5060
max-dn 200
max-pool 50
load 9951 sip9951.9-2-1.loads
load 3951 SIP3951.8-1-4a.loads
timezone 42
time-format 24
date-format YY-M-D
tftp-path flash:
create profile sync 0001838245531332
conference hardware
camera
video
voice register dn  1
number 2012
name system
label system
voice register dn  2
number 2013
name service
label service
voice register dn  3
number 2010
name GCC
label GCC
voice register dn  7
number 2018
name CP-7911
label CP-7911
voice register pool  1
id mac C8F9.F969.8B71
type 9951
number 1 dn 1
camera
video
voice register pool  2
id mac C8F9.F9D6.6B57
type 9951
number 1 dn 2
camera
video
voice register pool  3
registration-timer max 720 min 660
id mac FC25.3F20.3BFD
session-transport tcp
type CiscoMobile-iOS
number 1 dn 3
username gcc password 2010
video
voice register pool  7
id mac D057.4CF7.18D9
type 7911
number 1 dn 7
interface GigabitEthernet0/0
ip address 172.16.172.222 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 172.16.200.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
tftp-server flash:dkern9951.100609R2-9-2-1.sebn alias dkern9951.100609R2-9-2-1.sebn
tftp-server flash:kern9951.9-2-1.sebn alias kern9951.9-2-1.sebn
tftp-server flash:rootfs9951.9-2-1.sebn alias rootfs9951.9-2-1.sebn
tftp-server flash:sip9951.9-2-1.loads alias sip9951.9-2-1.loads
tftp-server flash:skern9951.022809R2-9-2-1.sebn alias skern9951.022809R2-9-2-1.sebn
tftp-server flash:apps11.9-2-3TH1-9.sbn alias apps11.9-2-3TH1-9.sbn
tftp-server flash:cnu11.9-2-3TH1-9.sbn alias cnu11.9-2-3TH1-9.sbn
tftp-server flash:cvm11sip.9-2-3TH1-9.sbn alias cvm11sip.9-2-3TH1-9.sbn
tftp-server flash:dsp11.9-2-3TH1-9.sbn alias dsp11.9-2-3TH1-9.sbn
tftp-server flash:jar11sip.9-2-3TH1-9.sbn alias jar11sip.9-2-3TH1-9.sbn
tftp-server flash:SIP11.9-2-3S.loads alias SIP11.9-2-3S.loads
tftp-server flash:term06.default.loads alias term06.default.loads
tftp-server flash:term11.default.loads alias term11.default.loads
control-plane
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 172.16.200.1 identifier 100 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/1
associate ccm 100 priority 1
associate profile 2 register VConfHomogens
associate profile 1 register confdsp1
dspfarm profile 1 conference
codec g729br8
codec g729r8
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
maximum sessions 1
associate application SCCP
dspfarm profile 2 conference video homogeneous
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
codec h264 cif frame-rate 15 bitrate 320kbps
maximum sessions 1
gatekeeper
shutdown
telephony-service
sdspfarm conference mute-on 111 mute-off 222
sdspfarm units 10
sdspfarm tag 1 confdsp1
sdspfarm tag 2 VConfHomogens
conference hardware
video
max-ephones 10
max-dn 100
ip source-address 172.16.200.1 port 2000
service phone paramEdibility 1
service phone videoCapability 1
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Jun 06 2012 14:55:33
ephone-template  2
softkeys hold  Newcall Resume Select Join
softkeys idle  Cfwdall ConfList Dnd Gpickup HLog Join Login Newcall Pickup Redial RmLstC
softkeys seized  Redial Pickup Gpickup HLog Meetme Endcall
softkeys connected  Acct ConfList Confrn Endcall Flash HLog Hold Join Park RmLstC Select Trnsfer
ephone-dn  1  dual-line
number 2011
label James
name James
ephone-dn  2
number 2100
label 7940
name 7940
ephone-dn  3
number 2006
label Jeffery
name Jeffery
ephone-dn  4  dual-line
number 2088
label 2088
name 2088
ephone-dn  99  octo-line
number 2AAA
conference ad-hoc
ephone-dn  100  octo-line
number ABCD
conference ad-hoc video
ephone  1
device-security-mode none
video-bitrate 512
video
mac-address 3C07.5427.D6C8
ephone-template 2
type CIPC
button  1:1
ephone  2
video
mac-address ECC8.82B0.E3DA
ephone-template 2
type 7940
button  1:2
ephone  3
video
mac-address 0010.0200.8083
type CIPC
button  1:3
ephone  4
video
mac-address 207C.8F84.821B
type CIPC
button  1:4
5 Replies 5
Ayodeji Okanlawon
Hi Guo,
Your configuration is missing the required config to enable hardware conferencing for sip phones..
you need to configure the ff:
conference hardware
For more options on the configuration please look at the link below:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmehwconf.pdf
Please rate useful posts
"I am complete in God, God completes me"
Please rate all useful posts
Hi aokanlawon,
Thank you reply.I have been configured this command "conference hardware"  in my configuration.
Guo
You have configures it on telephony-service (used by SCCP phones)
You need to configure
voice register global (used by sip phones)
conference hardware
The config you posted does not show this...
I have been configured this command in "voice register global" and "telephony-service".
mode cme
max-dn 200
max-pool 50
timezone 42
time-format 24
date-format YY-M-D
tftp-path flash:
conference hardware
camera
video
telephony-service
sdspfarm units 10
conference hardware
video
max-ephones 10
max-dn 100
Thanks a lot!
Can you do a test and sedn the ff debug:  please attach in a text file do not post them directly on the forum..
debug ccsip event
debug ephone mtp
