SIP Normalization - Remove Header
gpsriramdc
Level 4
Level 4
Hi All,
Just try to remove the Contact Header from the Inbound Messages to CUCM. I tried with the following syntax but there is no normalization happened.
Option 1:
M = {}
function M.inbound_ANY(msg)
msg:removeHeader("Contact")
end
return M
Option 2:
M = {}
if msg:getHeader("Contact")
then
end
return M
Ayodeji Okanlawon
Option should work...Did you apply the script to the sip trunk?
Can you send a sample trace from cucm..Perhaps the sytax for the contact field is different in the received invite.
The syntax for option two is not correct and you dont need to over complicate the script
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
