02-14-2017 09:42 PM - edited 03-17-2019 09:31 AM
Hello.
Could somebody clarify to me difference between "voice-class sip options-keepalive" and "voice-class sip options-ping"
voice-class sip ?
options-keepalive send out-of-dialogue OPTIONS PING to configured proxy/session-target
options-ping send in-dialogue OPTIONs to ping other endpoint
Which options should I use to monitor CUCM?
What is pros and conf of each method?
Is it safe to use both options simultaneously?
Solved! Go to Solution.
02-18-2017 09:39 PM
A call is known as a dialog in SIP. In-dialog would mean that the ping is done for a given Call-ID. You want "voice-class sip options-keepalive" so the keep alive messages are sent on their own, even if there isn't an active call.
On a related note, you should look at voice class sip-keepalive-profile.
02-18-2017 09:39 PM
