12-14-2015 02:58 AM - edited 03-17-2019 05:13 AM
We are using A Cisco 2951 as CUBE.
On one site we have a SIP trunk connected to our the SIP trunk provider and on the other side we have a SIP trunk to an IVR application.
The Provider sends an options PING to the CUBE and the CUBE answers. So...the Provider does know when the CUBE is up/down.
We also can send an option PING from the CUBE to the IVR and the IVR answers as well. So....the CUBE does know when the IVR is up/down.
The challenge:
What we want to achieve is that the Provider also knows when the IVR is down.
Is there is way to pass-through the IVR status to the Provider?
Any help is welcome.
Thanks in advance,
Wim
12-14-2015 03:24 AM
The only option is to bypass the CUBE and send options PING directly from the provider to the IVR. I doubt you want to do this. So it looks like its impossible with your current set up.
12-15-2015 09:55 PM
+5 for Ayodeji..
We cannot setup options ping directly from IVR to ITSP through CUBE.
Lavanya
