SIP Outgoing Call Error
HI,
I'm getting this message when im trying to take outside calls
*Sep 30 05:13:50.983: //-1/1563C6000000/CCAPI/cc_api_display_ie_subfields:
   cc_api_call_setup_ind_common:
   cisco-username=1001
   ----- ccCallInfo IE subfields -----
   cisco-ani=1001
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=119
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
   cisco-redirectreason=-1   fwd_final_type =0
   final_redirectNumber =
   hunt_group_timeout =0
*Sep 30 05:13:50.983: //-1/1563C6000000/CCAPI/cc_api_call_setup_ind_common:
   Interface=0x3E80F5A0, Call Info(
   Calling Number=1001,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=119(TON=Unknown, NPI=Unknown),
   Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
   Incoming Dial-peer=400, Progress Indication=NULL(0), Calling IE Present=TRUE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=32
*Sep 30 05:13:50.983: //-1/1563C6000000/CCAPI/ccCheckClipClir:
   In: Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
*Sep 30 05:13:50.987: //-1/1563C6000000/CCAPI/ccCheckClipClir:
   Out: Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
*Sep 30 05:13:50.987: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Sep 30 05:13:50.987: :cc_get_feature_vsa malloc success
*Sep 30 05:13:50.987:  cc_get_feature_vsa count is 1
*Sep 30 05:13:50.987: :FEATURE_VSA attributes are: feature_name:0,feature_time:1031466256,feature_id:32
*Sep 30 05:13:50.987: //32/1563C6000000/CCAPI/cc_api_call_setup_ind_common:
   Set Up Event Sent;
   Call Info(Calling Number=1001(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=119(TON=Unknown, NPI=Unknown))
*Sep 30 05:13:50.987: //32/1563C6000000/CCAPI/cc_process_call_setup_ind:
   Event=0x420A7958
*Sep 30 05:13:50.987: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
   Try with the demoted called number 119
*Sep 30 05:13:50.987: //32/1563C6000000/CCAPI/ccCallSetContext:
   Context=0xC0045478
   >>>>CCAPI handed cid 32 with tag 400 to app "_ManagedAppProcess_Default"
*Sep 30 05:13:50.987: //32/1563C6000000/CCAPI/ccCallProceeding:
*Sep 30 05:13:50.987: //32/1563C6000000/CCAPI/ccCallSetupRequest:
   Destination=, Calling IE Present=TRUE, Mode=0,
   Outgoing Dial-peer=500, Params=0xC00495C0, Progress Indication=NULL(0)
*Sep 30 05:13:50.987: //32/1563C6000000/CCAPI/ccCheckClipClir:
   Destination Pattern=1.., Called Number=119, Digit Strip=FALSE
   Redirect Number=, Display Info=Receptionist 2
   Account Number=1001, Final Destination Flag=TRUE,
   Guid=1563C600-0001-0000-0000-0011011810AC, Outgoing Dial-peer=500
*Sep 30 05:13:50.987: //32/1563C6000000/CCAPI/cc_api_display_ie_subfields:
   ccCallSetupRequest:
   cisco-username=1001
   cisco-ani=1001
   cisco-anitype=0
   cisco-aniplan=0
   cisco-anipi=0
   cisco-anisi=1
   dest=119
   cisco-desttype=0
   cisco-destplan=0
   cisco-rdie=FFFFFFFF
   cisco-rdn=
   cisco-rdntype=0
   cisco-rdnplan=0
   cisco-rdnpi=-1
   cisco-rdnsi=-1
*Sep 30 05:13:50.991: //32/1563C6000000/CCAPI/ccIFCallSetupRequestPrivate:
   Interface=0x3E80F5A0, Interface Type=3, Destination=, Mode=0x0,
   Call Params(Calling Number=1001,(Calling Name=Receptionist 2)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
   Called Number=119(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
   Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=500, Call Count On=FALSE,
   Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
*Sep 30 05:13:50.991: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
*Sep 30 05:13:50.991: :cc_get_feature_vsa malloc success
*Sep 30 05:13:50.991:  cc_get_feature_vsa count is 2
*Sep 30 05:13:50.991: :FEATURE_VSA attributes are: feature_name:0,feature_time:1031466032,feature_id:33
*Sep 30 05:13:50.991: //33/1563C6000000/CCAPI/ccIFCallSetupRequestPrivate:
   SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
*Sep 30 05:13:50.991: //33/1563C6000000/CCAPI/ccCallSetContext:
   Context=0xC0049570
*Sep 30 05:13:50.991: //32/1563C6000000/CCAPI/ccSaveDialpeerTag:
*Sep 30 05:13:50.991: //33/1563C6000000/CCAPI/cc_api_call_proceeding:
   Interface=0x3E80F5A0, Progress Indication=NULL(0)
*Sep 30 05:13:51.027: //33/1563C6000000/CCAPI/cc_api_call_disconnected:
   Cause Value=57, Interface=0x3E80F5A0, Call Id=33
   Call Entry(Responsed=TRUE, Cause Value=57, Retry Count=0)
*Sep 30 05:13:51.027: //32/1563C6000000/CCAPI/ccCallReleaseResources:
   release reserved xcoding resource.
*Sep 30 05:13:51.027: //33/1563C6000000/CCAPI/ccCallSetAAA_Accounting:
   Accounting=0, Call Id=33
*Sep 30 05:13:51.027: //33/1563C6000000/CCAPI/ccCallDisconnect:
   Cause Value=57, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=57)
   Cause Value=57, Call Entry(Responsed=TRUE, Cause Value=57)
*Sep 30 05:13:51.027: //33/1563C6000000/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3E80F5A0, Tag=0x0, Call Id=33,
   Call Entry(Disconnect Cause=57, Voice Class Cause Code=0, Retry Count=0)
   Call Disconnect Event Sent
*Sep 30 05:13:51.027: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Sep 30 05:13:51.027: :cc_free_feature_vsa freeing 3D7AEC28
*Sep 30 05:13:51.027:  vsacount in free is 1
*Sep 30 05:13:51.027: //32/1563C6000000/CCAPI/ccCallDisconnect:
   Cause Value=57, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
*Sep 30 05:13:51.031: //32/1563C6000000/CCAPI/cc_api_call_disconnect_done:
   Disposition=0, Interface=0x3E80F5A0, Tag=0x0, Call Id=32,
*Sep 30 05:13:51.031: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
*Sep 30 05:13:51.031: :cc_free_feature_vsa freeing 3D7AED08
*Sep 30 05:13:51.031:  vsacount in free is 0
8 Replies 8
Vivek Batra
Can you please share the output of show run to get the exact call flow...
Building configuration...
Current configuration : 5352 bytes
version 15.5
service password-encryption
hostname ICBT-HQ-GQ
boot-start-marker
boot-end-marker
enable secret 5 $1$OSEu$G1Q7ei4V9pwLUU65yrhnM.
no aaa new-model
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
ip dhcp excluded-address 172.16.24.1 172.16.24.10
ip dhcp excluded-address 172.16.24.254
ip dhcp excluded-address 172.16.24.1 172.16.24.15
ip dhcp excluded-address 172.16.24.22
ip dhcp excluded-address 172.16.24.23
ip dhcp excluded-address 172.16.24.26
ip dhcp excluded-address 172.16.24.21
ip dhcp excluded-address 172.16.24.24
ip dhcp pool ICBT_VOIP_POOL_1
 network 172.16.24.0 255.255.255.0
 default-router 172.16.24.254
 dns-server 172.16.0.1 172.16.0.2
 option 150 ip 172.16.24.1 172.16.24.3
 domain-name icbtcampus.edu.lk
no ip domain lookup
ip domain name icbtcampus.edu.lk
ip cef
no ipv6 cef
cts logging verbose
crypto pki trustpoint TP-self-signed-1277097745
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-1277097745
 revocation-check none
 rsakeypair TP-self-signed-1277097745
crypto pki certificate chain TP-self-signed-1277097745
 certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31323737 30393737 3435301E 170D3135 30393137 31383036
  33305A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 32373730
  39373734 3530819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100D2F5 ECBFEE7C 623AE47A 9D2080C8 1AC76F8E D7D84920 64B7C868 4FED1F1B
  DA554643 17A79F45 A5D438DC CF017C82 9F15305C 0748F68B 57BA4623 644457D9
  A9B907C8 22FDEB86 05DCD526 7F7A27B6 835C2025 ED787C36 225A3596 D63F8D9F
  CAF620EC 38294A14 BF1DCC78 A299BF25 D035631F 52905AB2 E627BD17 E636385E
  EBD30203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1462FCF4 9A5061F9 9E48C152 0F8C6306 39A6FE89 78301D06
  03551D0E 04160414 62FCF49A 5061F99E 48C1520F 8C630639 A6FE8978 300D0609
  2A864886 F70D0101 05050003 818100C3 D4802C7B 2220CF6C 1D3B585C 92F1BB22
  D260B702 A2F389CD 45E29072 85FF8CC0 7DCAB4E2 1E2E1FA9 23CF9B72 09087C0E
  E657EE09 CBD6B662 E4B8845F 00036354 819E0C83 627B51B3 4EB1A834 42F1340E
  073E434D 048DCAD1 DF20341E C36B71C2 4EE6417D D04C6306 D3F775CF 96F60665
  D71B8F87 6DFF0535 87D58CF4 4648E5
  quit
voice-card 0
 dsp services dspfarm
voice service voip
 ip address trusted list
  ipv4 172.16.24.1
  ipv4 172.16.24.2
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 supplementary-service h450.12
 no supplementary-service sip moved-temporarily
 no supplementary-service sip refer
 no supplementary-service sip handle-replaces
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  early-offer forced
voice class codec 1
 codec preference 1 g711ulaw
 codec preference 2 g711alaw
 codec preference 3 g729r8
 codec preference 4 g729br8
voice translation-rule 9
 rule 1 /^9\(.*\)/ /\1/
voice translation-profile STRIP9
 translate called 9
license udi pid CISCO2911/K9 sn FGL193011QE
hw-module pvdm 0/0
username admin privilege 15 password 7 15330F010D240B757A60
redundancy
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/1
 ip address 172.16.24.5 255.255.255.0
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
ip http authentication local
ip http secure-server
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 400 voip
 description SIP CALLS FROM CUCM TO CUBE
 session protocol sipv2
 incoming called-number 9.
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 500 voip
 description OUTGOING EMERGENCY CALLS TO SIP
 translation-profile outgoing STRIP9
 destination-pattern 91..
 session target ipv4:123.231.33.89
 voice-class codec 1
 max-redirects 5
 dtmf-relay rtp-nte digit-drop
 no vad
dial-peer voice 520 voip
 description OOUTGOING NATIONAL CALLS TO SIP
 destination-pattern 90[1-9]........
 voice-class codec 1
 max-redirects 5
 no vad
gatekeeper
 shutdown
line con 0
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 exec-timeout 0 0
 password 7 096D4A04100B3743595F
 login
 transport input all
line vty 5 15
 exec-timeout 0 0
 password 7 06270B2C454029485744
 login
 transport input all
scheduler allocate 20000 1000
end
Also please refer the following,
Sep 30 05:59:15.719: //3/49DA80800000/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x416E1E00
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 1001
Called Number            : 119
Source IP Address (Sig  ): 172.16.24.5
Destn SIP Req Addr:Port  : 123.231.33.89:5060
Destn SIP Resp Addr:Port : 123.231.33.89:5060
Destination Name         : 123.231.33.89
*Sep 30 05:59:15.719: //3/49DA80800000/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 172.16.24.5
Source IP Port    (Media): 16388
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
*Sep 30 05:59:15.719: //3/49DA80800000/SIP/Call/sipSPICallInfo:
Disconnect Cause (CC)    : 16
Disconnect Cause (SIP)   : 200
Dear Vivek,
Yes calls flow is CUCM -> CUBE -> SIP Provider, Please find the attachment
Well, as per traces, CUBE is sending INVITE to your provider but not getting any response hence call is being dropped. So either your provider is not getting INVITE or not responding. You can first check there is no issue with the network else need to check with provider why they are not responding to INVITE message.
Do you see any policy agreement with your provider what CLI should be send in INVITE message or any other requirement they have?
Dear Rajiv, I have sorted out the problem. There was a ip mismatch between ISP. Thanks a lot for your support
Good to know.
Call flow is like this?
Please also share the output of debug ccsip messages.
