SIP phones 9971/9951/Jabber - Ring no Answer issue
Tommer Catlin
Anyone have the same problem with redirects or ring no answer?   From SCCP to SIP phones internal, ring no answer I get the default Unity Connectio greeting.  If it hit the vm button on the SIP end point, I get prompted to login.  Which tells me, Direct is working, RNA is no working.  SCCPs do not have this problem.   CUCM 8.6.2 and CUC 8.6.2
Chris Deren
Is CUCM to UCON integration SCCP or SIP?
What are you seeing in the port monitor trace?
Chris
