SIP Phones
moussa.malqui1
Hi all,
I configured the GUI in CallManger Express for SCCP phones it's ok, but for SIP Phones don't appear in GUI.
where is the problem, SIP Phones aren't supported by the GUI?
thanks in advance,
Moussa
Jaime Valencia
Correct, the GUI only supports SCCP endpoints. You need to use CLI for SIP endpoints.
java
if this helps, please rate
Nadeem Ahmed
[+5] for Java
Just to add more point there were some enhancement opened for this however do not see any roadmap which can add this feature in upcoming version
https://tools.cisco.com/bugsearch/bug/CSCue49800/?reffering_site=dumpcr
Further if  you are well versed with CCP then probably you can SIP phone through a GUI interface.
Br,
Nadeem Ahmed
PS: Please rate all useful post.
Br, Nadeem Please rate all useful post.
