SIP Profile syntax question
Mamdouh Elgamal
My scenario is the following:
Region A Sites (east coast offices) ---------------------------------> CUCM --> Centralized CUBE B --> SIP Provier verizon Region A SBC
Cisco offices (direct registration to CUCM, no SRST)
PBX Sites (MGCP integration with CUCM)
Region B Sites (east coast offices)  ---------------------------------> CUCM --> Centralized CUBE B  --> SIP Provier verizon Region B  SBC
I'm expected to add outbound redundancy where Region A sites can route calls over CUBE B and Region B can route calls over CUBE A
The SIP provider screens caller id to verify that the DID Homed at the SBC its using, the screening is based off
Diversion Header and P-asserted-Identity Header
I've created the a SIP profile on each CUBE to modify the remote-party-ID header and add its content to the p-asserted-identity header, this is to allow the rerouting of calls, second its to also enable CFWD to an external party
Here is a short version of the profile:
voice class sip-profiles 1
request INVITE sip-header Remote-Party-ID modify "Remote-Party-ID:(.*>).*" "P-Asserted-Identity:\1"
request INVITE sip-header P-Asserted-Identity modify "P-Asserted-Identity: <sip:305.......@10.40.40.10>" "P-Asserted-Identity: <sip:2147750975@10.40.40.10>"
request INVITE sip-header P-Asserted-Identity modify "P-Asserted-Identity: <sip:248.......@10.40.40.10>" "P-Asserted-Identity: <sip:2147750975@10.40.40.10>"
request INVITE sip-header Diversion modify "Diversion: <sip:.*@.*>" "Diversion: <sip:2147750975@10.40.40.10:5060>"
I'd like to also add the following as the second to last rule in the SIP profile:
request INVITE sip-header P-Asserted-Identity modify "P-Asserted-Identity: (*>) <sip:\\+.*>"
I'm not sure if my syntax is wrong, but the above rule never seems to work. I have situations where the remote-party-id header contains a number beginning with a +
i.e Remote-Party-ID: "WIRELESS CALLER" <sip:+12487878187@10.40.40.10>;party=calling;screen=yes;privacy=off
does my syntax too good ?
any feedback is appreciated
Mando,
You can use this profile to strip off the + or +1
request INVITE sip-header P-Asserted-Identity modify "<>" "<>"
or
And you can use the same for Remote-Party-ID
request INVITE sip-header Remote-Party-ID  modify "<>" "<>"
NB: You might need to escape the + sign. If the above doesnt work use this..
If you want to strip the leading (1) along with the + just modify like this..
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Added profile to strip +1
8 Replies 8
Prashanthi Velpula
Hi Mando,
Can you please provide the complete INVITE message ? So that we have that as sample to test your profile ?
Once I have the complete INVITE message, will be happy to check the syntax for your profile config.
Prashanthi Velpula
The invites are from a CFWD scenario. Cisco phone 956 278 8599 is forwarded to 248 787 8187
a PSTN caller 305 205 2046 is dialing 956 278 8599
CUCM ip address 10.1.40.102 and CUBE is 10.40.40.10
SIP SBC 172.X.X.X
CUCM --> CUBE (this is where i would be applying the sip profile)
*Oct 16 22:28:06.483: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:912487878187@10.40.40.10:5060 SIP/2.0
Via: SIP/2.0/TCP 10.1.40.102:5060;branch=z9hG4bK49189b34dc22a3
From: "WIRELESS CALLER" <>;tag=18095909~aaf222e9-fc5e-4552-95a5-9433ef6cdd7d-47147943
To: <912487878187>
Date: Wed, 16 Oct 2013 22:35:04 GMT
Call-ID: 3224a180-25f11498-1d3df1-6628010a@10.1.40.102
Supported: 100rel,timer,resource-priority,replaces
Min-SE:  1800
User-Agent: Cisco-CUCM8.6
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence
Supported: X-cisco-srtp-fallback
Supported: Geolocation
Cisco-Guid: 0841261440-0000065536-0001024219-1713897738
Session-Expires:  86400
P-Asserted-Identity: "WIRELESS CALLER" <>
Remote-Party-ID: "WIRELESS CALLER" <>;party=calling;screen=yes;privacy=off
Contact: <>
Max-Forwards: 67
Content-Type: application/sdp
Content-Length: 214
v=0
o=CiscoSystemsCCM-SIP 18095909 1 IN IP4 10.1.40.102
s=SIP Call
c=IN IP4 10.40.40.10
t=0 0
m=audio 16818 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
CUBE --> SIP Provider
*Oct 16 22:28:06.485: //425194/3224A180000F/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:12487878187@172.30.223.17:5337 SIP/2.0
Via: SIP/2.0/UDP 10.40.40.10:5060;branch=z9hG4bK59097BB8
To: <12487878187>
Date: Wed, 16 Oct 2013 22:28:06 GMT
Call-ID: 10173568-35E911E3-AF9EA495-29959B78@10.40.40.10
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
User-Agent: Cisco-SIPGateway/IOS-15.2.4.M4
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1381962486
Contact: <>
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 66
Content-Disposition: session;handling=required
Content-Length: 242
v=0
o=CiscoSystemsSIP-GW-UserAgent 9917 12 IN IP4 10.40.40.10
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Hi Mando,
Thank you for the INVITE sample, below is a result of what you have:
With just the below profile, i am showing the output, please let me know if this is your requirement:
BEFORE:
AFTER:
With just the below profile, i am showing the output, please let me know if this is your requiremen ?
( Modified your existing profile )
request INVITE sip-header P-Asserted-Identity modify "<.>" "<2147750975>"
BEFORE:
AFTER:
P-Asserted-Identity: "WIRELESS CALLER" <2147750975>
The other profiles, are incorrect, as they are NOT modifying the INVITE message:
THERE IS NO CHANGE WITH BELOW PROFILES
request  INVITE sip-header P-Asserted-Identity modify "P-Asserted-Identity:  <305.......>" "P-Asserted-Identity:  <2147750975>"
request INVITE sip-header  P-Asserted-Identity modify "P-Asserted-Identity:  <248.......>" "P-Asserted-Identity:  <2147750975>"
request INVITE sip-header Diversion modify "Diversion: <.>" "Diversion: <2147750975>"
Please let me know what is your requirement ? Based on that I will help you create the sip-profile ? Or is the above AFTER outputs valid and suits your requirement ?
Prashanthi Velpula
is it possible to match any number starting with a + ? that's the issue that i was having, i don't want a vague match like
i need it to be specific to +1XXXXXXXXXX
basically the following:
request INVITE sip-header P-Asserted-Identity modify "<>" "<2147750975>"
Hi Mando,
++ The above line is modifying the Remote-Party-ID to P-Asserted-Identity header , and below is the output:
BEFORE:
AFTER applying the profile:
Is the above your requirement ?
++ If yes, what is the need to send two P-Asserted-Identity headers to provider ?
Coming to the below profile:
++ This is incorrect syntax
++ If you need to modify P-Asserted-Identity header as below:
- Modify "+13052052046" TO "2147750975", Then below is what you will need:
++ The above profile is picking the "+13052052046" and modifying TO "2147750975"
( Please confirm if this is your requirement ? )
And yes, this is modifying the extension starting with + , it actually also means , anything in that "<.>" WILL BE modified to "<2147750975>"
Hope the above is more informative.
Prashanthi Velpula
Mando,
or
Thanks!
I have scratched SIP Profile desgin discussed in this post and came up with this alternative that works much better for me and allows for failover between different sites.
Region  A Sites (east coast offices) ---------------------------------> CUCM  --> Centralized CUBE A--> SIP Region A SBC
Region  B Sites (east coast offices)  --------------------------------->  CUCM --> Centralized CUBE B  --> SIP Region B  SBC
Inorder to allow :
Region A sites --> CUBE B --> Region B
i've created the following sip profile on CUBE B:
request INVITE sip-header Contact copy "<>" u01
request INVITE sip-header Diversion add "Diversion: "
request INVITE sip-header Diversion modify "Diversion: " "Diversion: <>"
request INVITE sip-header Diversion modify "<>;privacy=off;reason=unconditional;screen=yes"
request INVITE sip-header Diversion modify "<1..........>;privacy=off;reason=unconditional;screen=yes"
request INVITE sip-header Diversion modify "<305.......>;privacy=off;reason=unconditional;screen=yes"
request INVITE sip-header Diversion modify "<248.......>;privacy=off;reason=unconditional;screen=yes"
request INVITE sip-header Diversion modify "<212.......>;privacy=off;reason=unconditional;screen=yes"
request INVITE sip-header Diversion modify "<215.......>;privacy=off;reason=unconditional;screen=yes"
request INVITE sip-header Diversion modify "<201.......>;privacy=off;reason=unconditional;screen=yes"
request INVITE sip-header Diversion modify "<202.......>;privacy=off;reason=unconditional;screen=yes"
request INVITE sip-header Diversion modify "<312.......>;privacy=off;reason=unconditional;screen=yes"
request INVITE sip-header Diversion modify "<404.......>;privacy=off;reason=unconditional;screen=yes"
request INVITE sip-header Diversion modify "<856.......>;privacy=off;reason=unconditional;screen=yes"
request INVITE sip-header Diversion modify "<919.......>;privacy=off;reason=unconditional;screen=yes"
request INVITE sip-header Diversion modify "<....>;privacy=off;reason=unconditional;screen=yes"
request INVITE sip-header Diversion modify "<.......>;privacy=off;reason=unconditional;screen=yes"
