Sip profile to change outbound Calling Name from ASCII Caller ID to Company Name
joeharb
Level 5
Level 5
Out bound calls through a SIP trunk are displaying the ASCII Caller ID.  I am attempting to change that to all call display the same value, I have found multiple posts and attempted the following:
voice class sip-profiles 1
request INVITE sip-header From modify "^\"\([A-Za-z0-9 ]+\)\"[ \t]+\(<.*\)$" "\"Company Name\" \2"
This is applied to the inbound dial-peer from Call Manager.
The current From message on the invite is as follows:
From: "Test CallerID" <sip:XXXXXXXXX@YY.YY.YY.YY>;tag=402238~2ec47342-56ea-4c6e-9d2b-c5e8eaf44c32-113749149
I not confident that this is what needs to change and I am not able to see that the sip profile is even making any changes...the invite sent to the provider has exactly the same information.
Please advise,
Joe
elavoie
Inbound modifications requires that you enable, "sip profile inbound" under voice service voip/sip
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-sip-param-mod.html#task_732EE9481AB14D56884F9F06A14DB4A5
However, you could just apply it on the outbound dial-peer to your SIP provider with a simple rule like this one.
request ANY sip-header From modify "\".*(<sip:.*)" "\"ACME inc.\" \1"
You can test your SIP Profile with this online tool too.
https://cway.cisco.com/tools/SipProfileTest/
