SIP Proxy IP
eberrocal2
I'm setting up a fax service and being prompted for SIP Proxy IP/SIP Proxy Gateway IP.  Where can I find this IP address?  Thanks!
Then simply point to your CUCM IP address(es) as the Proxy/GW destinations.  Obviously you'll need to build the integration between CUCM and the fax server, i.e. SIP trunk. I would imagine the FAXFinder would have documentation on how to do that on their side.
8 Replies 8
Chris Deren
What are you integrating this fax service to? Assuming your fax service is SIP based on the question you need to route phone calls (faxes) to/from this service which will be done via either an on-prem IP-PBX or hosted solution or directly by telco, so the SIP proxy/GW would be that component.
Chris, you're right.  I need the IP address of that SIP proxy/GW?  How do I find that?  Thanks!
What are you connecting your Fax server to?
It's a MultiTech FAXFinder appliance.  We're setting it up in CallManager.
Thanks.
Thanks Chris!
No problem, let us know if you have any additional questions. Otherwise please mark the thread as answered.
