SIP SRST 3905 issue please help
Now I have testing sip srst 3905 and SCCP 7962  when cucm down its register with CME but 3905 can't call to 7962  but 7962 can call 3905 when I off-hook I got busy tone please see config below
voice service voip
 allow-connections h323 to sip
 allow-connections sip to h323
 allow-connections sip to sip
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  registrar server expires max 600 min 60
voice class codec 1
 codec preference 1 g711alaw
 codec preference 2 g711ulaw
 codec preference 3 g729r8
voice register global
 mode srst
 system message srst active
 max-dn 100
 max-pool 100
voice register pool  1
 id network 192.168.100.0 mask 255.255.255.0
 dtmf-relay rtp-nte cisco-rtp sip-notify
 no vad
At the cucm(192.168.100.102) srst reference I config IP address and Sip network already advise me if anything is missing ....
You are missing bind command and source interface.
voice service voip
bind all source  x/x
source-address x.x.x.x
Please add these and test. If things didn't work, please share debug ccsip mess
6 Replies 6
Jonathan Unger
Level 7
Level 7
Please try configuring the following:
voice service voip
ip address trusted list
ipv4 192.168.100.0 255.255.255.0
If that does not work enable "voice iec syslog" (in global config) and debug ccsip messages (ensure you log buffer is large enough to capture everything)  when in SRST, then reproduce the 3905 busy issue.
Once you do this can you please post a copy of the "show log command"?
Additionally, what version of IOS are you running?
Hello jonathan
    My version IOS is 15.5.let me test I will update again
voice service voip
bind all source  x/x
Hi Natt,
Did you apply the bind command what is the results?
Laith Ibrahim
under the sip, try to add:
bind control source-interface <your srst interface>
bind media source-interface <your srst interface>
and then in the voice register global apply the command:
create profile
Hi Mohammad
    That is work
Nattapong
