SIP SRST 8.X problem
Yue bun Yuen
In the SRST Admin Guide, I find the Translation profile can be apply to the Voice register pool under SIP SRST mode, but it doesn't work !! any one has idea about it?
Router(config-register-pool)#
voice translation-rule 1
rule 1 /1000/ /1006/
voice translation-profile 1
translate called 1
voice register pool xxx
translation-profile outgoing 1        <---------------- translation
guilhem.perez
Level 4
Level 4
I meet the same issue.
Did you solve your issue?
Thank you
Best regards
There may be a bug here
CSCse37273 Bug Details
Need Voice Translation Profile for SIP SRST Phones
Symptom:
Voice Translation Profiles cannot be applied to SIP SRST phones.
Condition:
None
Work-around:
None
You will need to look at the IOS version to see if you are affected
Status
Status
Fixed
(Resolved)
Severity
Severity
3 - moderate
Last Modified
Last Modified
In Last Year
Product
Product
Cisco IOS software
Technology
Technology
1st Found-In
1st Found-in
12.4M
Known Affected Versions
KAV
Fixed-In
Fixed-in
12.4(22)YB
12.4(23.8)PI10
12.4(23.15)T1
12.4(23.15.1)PIX11
12.4(23.15.4)PIC1
12.4(24.5.1)PIX11
Component(s)
Component
sip-srst
Also in the new BETA toolkit
It shows many other versions included as affected on IOS 15
Alex
Please rate useful posts
Regards, Alex. Please rate useful posts.
