04-18-2011 01:17 AM - edited 03-16-2019 04:33 AM
In the SRST Admin Guide, I find the Translation profile can be apply to the Voice register pool under SIP SRST mode, but it doesn't work !! any one has idea about it?
Router(config-register-pool)#
voice translation-rule 1
rule 1 /1000/ /1006/
voice translation-profile 1
translate called 1
voice register pool xxx
translation-profile outgoing 1 <---------------- translation
11-28-2011 03:22 AM
I meet the same issue.
Did you solve your issue?
Thank you
Best regards
11-28-2011 04:56 AM
There may be a bug here
You will need to look at the IOS version to see if you are affected
Status
Fixed
(Resolved)
Severity
3 - moderate
Last Modified
In Last Year
Product
Cisco IOS software
Technology
1st Found-In
12.4M
Fixed-In
12.4(22)YB
12.4(23.8)PI10
12.4(23.15)T1
12.4(23.15.1)PIX11
12.4(23.15.4)PIC1
12.4(24.5.1)PIX11
Component(s)
sip-srst
Also in the new BETA toolkit
It shows many other versions included as affected on IOS 15
Alex
Please rate useful posts
