SIP to FXO not working
mike_cynnex
Community Member
I have have 2 UC series boxes connected via SIP dial-peers.  Read as simple site-to-site peers.
Box 1 has an FXO port connected to the PSTN.
If a call comes in from box 2 via the SIP dial-peer, with digits matching the destination-pattern of the POTS dial-peer, the call fails.
If I attempt to dial the same pattern from a registered SCCP phone on box 1, the call succeeds via the POTS line.
I also tested with x-lite SIP client pointing it to an inside IP of box 1 dialing the same pattern and the call failed to complete via the POTS.
Also on Box 1 I have a SIP trunk to an ITSP and all calls to that trunk via any phone, including unregisterd x-lite, complete successfully.
It is only when I attempt an outbound call that is SIP to FXO.
Ideas?
Christopher Graham
Have you taken any debugs on box 1 for a failed call?  Are you sure you are hitting the correct pots dial peer?  We would need to see the following debugs to determine why the call if failing:
debug voip ccapi inout
debug ccsip mess
debug vpm sig
You dial-peer config would be needed as well.
Thanks for the debug commands.
I figured it out...I was missing a dial-peer for the SIP leg of the call.  The system had VOIP dial-peers for patterns prefixed with '9', but this particular pattern was prefixed with '8' to force the call to the FXO port rather than use the SIP trunk.
