SIP trunk between CUCM and ISP
ggl277808
Hi team,
Has anyone know how to change the option sip max-forwards to value "1" in CUCM 10.5 version?
Thanks in advance
R0g22
I responded to your other post yesterday but I believe you did not notice my reply. You can use the following script for normalization -
M = {}
function M.outbound_OPTIONS(msg)
msg:removeHeader("Max-Forwards")
msg:addHeader("Max-Forwards", "1")
end
return M
These are not TAC supported.
https://supportforums.cisco.com/t5/ip-telephony/sip-trunk-integration-isp/m-p/3337989#M358490
Aeby Vinod
Level 3
Level 3
here is a similar thread you can refer to:
https://supportforums.cisco.com/t5/ip-telephony/cucm-sip-trunk-max-forward/td-p/2635151
Please rate if found helpful
Aeby
Please rate if you find this helpful.
Aeby
Hi Aeby,
Thanks for your response, I had seen this post before, and it is the same doubt that I have, but the answer and the example is over the configuration of a CUBE.
What I need is to change this parameter directly under the Sip Trunk configuration, by some option if it exists, although I have not found, or through Lua script normalization, which I have not found either.
Any clue?
R0g22
M = {}
end
return M
Hi Nipun,
I've solved the issue with your function.
Thank you so much
