SIP TRUNK between CUCME and Grandstream PBx
markmarvinq
Does any one any tried to do SIP trunk on Grandstream Pabx and CUCME router?
i tried to do sip trunk but not working.
Please help how to configure sip trunk
Thanks and regards
R0g22
For starters, query the vendor for the following -
1. IP addresses to use. Public IP for the vendor which will receive and respond to requests from CME.
2. Will the SIP trunk require Registration ? If yes, credentials and registrar information.
3. Will proxy authentication be required ? If yes, credentials/authentication information need to be shared.
4. Will they support 302/Refer for call forwarding/transfers ? If not, disable them to avoid call failure in these scenarios.
Linked doc should be helpful -
https://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-express/91535-cme-sip-trunking-config.html
