SIP Trunk Cisco <-> Asterisk with ILBC Codec
evandrojnabor
I'm having problems with this situation
I've configured asterisk to permit codecs preferece 1 - ilbc and 2 - alaw
When I make a call from Cisco FXS port -> Asterisk extension, everything works fine, the codec chosen is ILBC and the voice quality is ok.
Calls from Asterisk extension -> Cisco FXS extension always use codec alaw and the voice quality is not good.
I'm using snmp to monitor the interfaces to know what codec the devices are using.
This is my Cisco router configuration
http://pastebin.com/pwMTxGEv
This is the log from debug ccsip all
http://pastebin.com/d9d9hUwr
Ayodeji Okanlawon
From the logs, here is what I see...
26.m=audio 16568 RTP/AVP 97 101
27.a=rtpmap:97 iLBC/8000
28.a=fmtp:97 mode=30
Jan 22 17:31:44.295: //-1/xxxxxxxxxxxx/SIP/Info/rtpAvpCodec_to_voipCodec: Dynamic Payload :97 in SDP Body
The Asterisk box is negotiating payload 97 for ilbc codec....The problem with this is that this is a pre-configured payload type on cisco gateways as "cisco-codec-fax-ack"
You need to change the payload type for 97 on the router...
conf t
rtp payload-type cisco-codec-fax-ack 104
After you make the change..test again and send debug ccsip all from the cisco router
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Ayodeji Okanlawon
conf t
evandrojnabor
Very nice, the problem is solved!
Thank you very much!
You are most welcome!
