SIP trunk - CUBE - one way audio
Hi guys,
I am having a problem deploying a new SIP trunk to a customer.
The scenery is the following:
PSTN———>GW (CUBE)————>CUCM——-------------->IP PHONE
PSTN = Internet link with SIP trunk
GW (CUBE) = Cisco 2901 router
CUCM = CallManager 8.6
IP Phone = Cisco IP Phone
PS: There is a SonicWall firewall between the PSTN and GW
The problem is: When a call is established from outside to inside, only the outside guy listen the inside guy.
Audio = Outside (PSTN) ---------------> Inside (Customer) = Not OK. The customer can't hear me.
Audio = Outside (PSTN) <--------------- Inside (Customer) = OK. I can hear the customer from outside.
PS: For security reasons, I am hiding the SIP public address:
SIP address: 88.x.x.9 and 88.x.x.10
Signalling:UDP port 5060 egress/ingress to:- 88.x.x.9
Media: All UDP ports between 6000 - 40000 egress/ingress to:- 88.x.x.10
Cisco Router GW 2901 Ip address is 192.168.4.40
CUCM are 192.168.4.32 and 37 (PUB and SUB)
Cisco Router Configuration:
voice service voip
  mode border-element license capacity 10
  allow-connections sip to sip
   allow-connections sip to h323
  allow-connections h323 to sip
 ip address trusted list
  ipv4 88.x.x.9
  ipv4 88.x.x.10
  ipv4 192.168.4.32
  ipv4 192.168.4.37
  sip
    bind control source-interface g0/0
    bind media source-interface g0/0
    early-offer forced
   header-passing
   error-passthru
   midcall-signaling passthru
 dspfarm profile 1 transcode
 codec g711ulaw
 codec g711alaw
 codec g729ar8
 codec g729abr8
 codec g729r8
  associate application cube
  maximum session 10
 no shut
dial-peer voice 31 voip
 description *** WAN side - Incoming from ITSP ***
 session protocol sipv2
 incoming called-number .
 dtmf-relay rtp-nte
 codec g711alaw
 voice-class sip rel1xx supported 1xx
dial-peer voice 32 voip
 description *** All CUCM 4320-4359 Extensions ***
 destination-pattern 43..
 session target ipv4:192.168.4.32
 voice-class sip bind control source-interface GigabitEthernet0/0
 voice-class sip bind media source-interface GigabitEthernet0/0
 dtmf-relay h245-alphanumeric
 codec g711ulaw
dial-peer voice 33 voip
 session target ipv4:192.168.4.37
 codec g711ulaw
dial-peer voice 36 voip
 description ** WAN Side dial-peer Long Distance**
 destination-pattern 9T
 voice-class sip bind control source gig0/0
 voice-class sip bind media source gig0/0
 session target ipv4:88.x.x.9
 codec g711alaw
We are not receiving an ACK from ITSP, as we can see below:
07492991578 is my mobile (called)
0yyyyyy4322 is the calling number. (Customer)
195.x.x.1 is the Customer Public IP address = redirect (NAT) to Cisco GW 2901 = 192.168.4.40
1.- INVITE received from ITSP  (ITSP -> CUBE)
016873: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0yyyyyy4322@195.x.x.1;user=phone SIP/2.0
Max-Forwards: 69
Session-Expires: 3600;refresher=uac
Min-SE: 600
Supported: timer, 100rel
To: <sip:0yyyyyy4322@88.x.x.9:5060;user=phone>
P-Asserted-Identity: <sip:07492991578@88.x.x.9;user=phone>
Call-ID: 383666-3659783180-846070@MSX76.gammatelecom.com
CSeq: 1 INVITE
Allow: PUBLISH,MESSAGE,UPDATE,PRACK,SUBSCRIBE,REFER,INFO,NOTIFY,REGISTER,OPTIONS,BYE,INVITE,ACK,CANCEL
Via: SIP/2.0/UDP 88.x.x.9:5060;branch=z9hG4bK85ba699fee73d1559b04acfea3aa828a
Contact: <sip:07492991578@88.x.x.9:5060>
Content-Type: application/sdp
Accept: application/sdp
Content-Length: 210
v=0
o=MSX76 80522071823619324 1 IN IP4 88.x.x.9
s=sip call
c=IN IP4 88.x.x.10
t=0 0
m=audio 26420 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
2.- CUBE replies with a 100 Trying (CUBE -> ITSP)
016934: //12497/71FD5783B246/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Tue, 22 Dec 2015 14:30:55 GMT
CSeq: 1 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.5.1.T
Content-Length: 0
3.- CUBE sends INVITE to CUCM (CUBE -> CUCM)
016935: //12498/71FD5783B246/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:0yyyyyy4322@192.168.4.32:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.4.40:5060;branch=z9hG4bK19A3144A
Remote-Party-ID: <sip:07492991578@192.168.4.40>;party=calling;screen=no;privacy=off
From: <sip:07492991578@192.168.4.40>;tag=22A6F1E4-2061
To: <sip:0yyyyyy4322@192.168.4.32>
Call-ID: 71FFC8BC-A7EF11E5-B24CED9B-9CD509BC@192.168.4.40
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 1912428419-2817462757-2990992795-2631207356
User-Agent: Cisco-SIPGateway/IOS-15.5.1.T
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1450794655
Contact: <sip:07492991578@192.168.4.40:5060>
Expires: 180
Max-Forwards: 68
Content-Disposition: session;handling=required
Content-Length: 296
v=0
o=CiscoSystemsSIP-GW-UserAgent 6851 7202 IN IP4 192.168.4.40
s=SIP Call
c=IN IP4 192.168.4.40
t=0 0
m=audio 22492 RTP/AVP 8 100 101
a=rtpmap:100 X-NSE/8000
a=fmtp:100 192-194
a=fmtp:101 0-15
a=ptime:20
4.- CUBE receives 100 Trying and 180 Ringing from CUCM
016936: //12498/71FD5783B246/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Date: Tue, 22 Dec 2015 14:26:20 GMT
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
016937: //12498/71FD5783B246/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
To: <sip:0yyyyyy4322@192.168.4.32>;tag=3056396~5b01f916-ff84-482b-b2b5-cacb0ac4ceff-29806313
CSeq: 101 INVITE
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
Supported: X-cisco-srtp-fallback
Supported: Geolocation
P-Asserted-Identity: "IT" <sip:20010@192.168.4.32>
Remote-Party-ID: "IT" <sip:20010@192.168.4.32>;party=called;screen=yes;privacy=off
Contact: <sip:0yyyyyy4322@192.168.4.32:5060>
Content-Length: 0
5.- CUBE sends 180 Ringing  to ITSP
016943: //12497/71FD5783B246/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
To: <sip:0yyyyyy4322@88.x.x.9:5060;user=phone>;tag=22A6F248-1B4A
CSeq: 1 INVITE
Remote-Party-ID: "IT" <sip:20010@192.168.4.40>;party=called;screen=yes;privacy=off
Contact: <sip:0yyyyyy4322@192.168.4.40:5060>
Content-Length: 0
6.- CUCM sends CUBE 200 OK
017055: //12498/71FD5783B246/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Allow-Events: presence, kpml
Supported: replaces
Require:  timer
P-Asserted-Identity: "Paul Kelly" <sip:20010@192.168.4.32>
Remote-Party-ID: "Paul Kelly" <sip:20010@192.168.4.32>;party=called;screen=yes;privacy=off
Content-Length: 211
v=0
o=CiscoSystemsCCM-SIP 3056396 1 IN IP4 192.168.4.32
s=SIP Call
c=IN IP4 10.1.1.1
t=0 0
m=audio 22494 RTP/AVP 8 101
a=ptime:20
a=fmtp:101 0-15
7.- CUBE replies to CUCM with an ACK
017077: //12498/71FD5783B246/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:0yyyyyy4322@192.168.4.32:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.4.40:5060;branch=z9hG4bK19A4655
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
8.- CUBE sends 200 OK to ITSP
017114: //12497/71FD5783B246/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Remote-Party-ID: "Paul Kelly" <sip:20010@192.168.4.40>;party=called;screen=yes;privacy=off
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 247
v=0
o=CiscoSystemsSIP-GW-UserAgent 5216 2338 IN IP4 192.168.4.40
s=SIP Call
t=0 0
m=audio 22490 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
9.- CUBE resends 200 OK to ITSP because CUBE is expecting to receive an ACK message from ITSP (CUBE resends the 200 OK for 7 times)
017116: //12497/71FD5783B246/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Remote-Party-ID: "Paul K" <sip:20010@192.168.4.40>;party=called;screen=yes;privacy=off
Supported: replaces
Supported: sdp-anat
Require: timer
Supported: timer
Content-Length: 247
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
10.- As CUBE does not receive the ACK after 7 attempts to send the 200 OK, CUBE ends the call
017241: //12497/71FD5783B246/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:07492991578@88.x.x.9:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.4.40:5060;branch=z9hG4bK19A51CC4
From: <sip:0yyyyyy4322@88.x.x.9:5060;user=phone>;tag=22A6F248-1B4A
To: <sip:07492991578@88.x.x.9>;tag=dztfn5od
Max-Forwards: 70
Timestamp: 1450794683
CSeq: 101 BYE
Reason: Q.850;cause=86
P-RTP-Stat: PS=970,OS=155200,PR=0,OR=0,PL=0,JI=0,LA=0,DU=19
Content-Length: 0
11 Replies 11
Graham Old
Level 7
Level 7
I would be looking at the setup for the Sonicwall Firewall. It looks like it may not be handling the SIP protocol correctly.
In your first INVITE from the ITSP you have this
I would have expected the Sonicwall to have converted the 195.x.x.1 IP address to the CUBE on 192.168.4.40
When you send the ACK to the ITSP you are defining the IP audio address as
You need the Sonicwall to convert that to the 195.x.x.1 address, If its failing to convert the INVITE its probably not converting the Audio IP address on the output.
Can you do a wireshark between the Sonicwall and the PSTN and check the Sonicwall is converting the IP addresses correctly
Graham
We are doing NAT from 192.168.4.40 to 195.x.x.1 (Public IP Address).
We can ping from 192.168.4.40 to 88.x.x.9.
The NAT is done after the Sonic Wall, in the ISP router.
I will return on 5th january at the customer and I will collect wireshark files.
You can't do a simple NAT to convert the IP address on SIP. You must have a SIP helper process that converts the IP address in the SIP protocol as well.
Why do you need to do NAT. Can you not assign the 195.x.x.1 address to the second NIC on the CUBE and make it do all the work. That is what CUBE's are for. To be the border element, to convert IP address and to provide security.
You need to setup a few extra things for security. I would suggest an access list on the second NIC to limit the IP address to Gamma's two IP address and the UDP port numbers. You should also make the IP routing to Gamma's IP address pretty tight.
I would suggest a few other things if you are able to connect the CUBE direct.
Graham
Rodrigo,
I'm not sure if you were able to resolve your problem, however I figured I would give you my two cents.  Graham has pretty much giving you some good suggestions.. I had a similar issue with Sonicwall, but mine was more of an issue with Expressway behind a Sonicwall.  The jabber clients had one-way audio.  I must have changed every possible SIP ALG setting in the sonic wall to correct my issue with NAT.  I was unable to find the right combination to make it successfully work.  Note, I was able to get this same setup to work fine behind an ASA without issue.  However, again "SIP INSPECTION" had to be turned on with the ASA for it to work.
Now considering my issue was with Expressway, i was able to convince the customer to move the Expressway-E outside of the Sonicwall.  This ultimately solved my problem for this particular customer.
The suggestion that Graham has mentioned with using a second interface and directly attaching the CUBE is a solution that we know will work without issue.   Just be sure to enable/configure the IOS firewall rules on the cube as well as lock it down to avoid any SIP Toll-Fraud attempts.
thanks,
Ayodeji Okanlawon
The reason why you are not getting ACK back from ITSP is that ACK is sent to the host filed in the contact header.
The address in the contact header here looks like its not reachable from your ITSP as it is a private address. Please correct this and your issue should be resolved
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Please rate all useful posts
Your Nat isn't working correctly. The 200 OK contains the private ip add in the contact header. This is one of the issues with Nat. You need a device that can do SIP ALG.
As long as your contact header contains the private ip, your ITSP can't send ACK to the 200 OK
I understood what you mean.
The NAT is translating the ip header but not the SIP header.
I will check that on Tuesday.
Hi Ayodeji,
I will try to modify the SIP header with the configuration below on Tuesday. What do you think?
voice class sip-profiles 10
 request INVITE sip-header From modify "<sip:(.*)@195.x.x.1>” "<sip:\1@192.168.4.40>”
request ACK sip-header From modify "<sip:(.*)@195.x.x.1>” "<sip:\1@192.168.4.40>”
dial-peer voice 31 voip   => (incoming SIP Calls)
 voice-class sip profiles 10
voice class sip-profiles 20
request INVITE sip-header From modify "<sip:(.*)@192.168.4.40>” "<sip:\1@195.x.x.1>”
request ACK sip-header From modify "<sip:(.*)@192.168.4.40>” "<sip:\1@195.x.x.1>”
dial-peer 32/33 voip => (outgoing SIP calls)
 voice-class sip profiles 20
I haven't solved the problem yet.
Any idea to do the SIP ALG?
The ITSP is not sending the ACK to the 200 OK and it is not sending media from (88.x.x.10) to CUBE.
Only the CUBE is sending media to 88.x.x.10, that is the reason that only me can hear the customer.
