Hi guys,
I have this problem: I have a SIP trunk with a Nortel CS1000, comunicating by wan, when I call from CUCM to Nortel, everithing is fine. But From Nortel to Cisco, I dont have signaling or voice. Checking a capture, I see this format sending by Nortel
It shows many SIP invite received by my CUCM but do not answer. And checking by packet it has the format phone-context=udp@domain
I think it is not an standard SIP format, some forums said that it is not supported by CUCM. But it is? so CUCM cant be integrated with cs1000?
I check sdi logs and I cant found any error, so I not really sure if it is the cause for call failed.
Somebody can help me
Thanks in advance
Carlos,
When you read the Cisco interoperability
portal pdf for CUCM8.5 SIP to CS1K on page
58 you can see that a normalisation script
should be ran to negate the use of "phone-context"
from invites etc.
May be this can help
http://www.cisco.com/en/US/solutions/collateral/ns340/ns414/ns728/ns784/989942.pdf
Alex.
Please rate useful posts.
