LDAP authentication fails in CUCM 9.0
Stefan Wahl
Hi everybody,
I've got problems to get LDAP authentication running in CUCM 9.0
I configured the required points:
- LDAP System (MS AD with sAMAccountName)
- LDAP Directory configured (with LDAP Filter)
- LDAP Authentication enabled (same credentials/servers as in LDAP directory)
When I now try logon to ccmadmin/ucmuser/Jabber phone profile I get error message, which says: Wrong username or password.
The MS AD is version 2008
Are there any known errors or is there something a have to take a look at?
I rebooted the server several times, but this didn't help.
Thanks for your help.
Stefan
Jonathan Schulenberg
Care to attach a screenshot of the LDAP Directory and Authentication screens? Usually this is because you have the search base (CN=Users,DC=domain,DC=com) or bind DN (CN=Display Name,OU=People,DC=domain,DC=com) setup incorrectly.
Also check that the LDAP Status remains Active on the End User Configuration page search results after doing a full sync. If it goes Inactive then CUCM is not seeing that user returned from LDAP.
Please remember to rate helpful responses and identify helpful or correct answers.
