01-11-2011 02:08 PM - edited 03-16-2019 02:48 AM
We have a SIP trunk from our CallManager 8.0 to our Service Provider and are having some QoS issues with jitter, call drops, etc. How to you assign QoS to a trunk that is terminated to CallManager and not to a router?
Solved! Go to Solution.
01-24-2011 07:07 AM
no worries,
first we need to classify the traffic, Im going to do this the lazy way using nbar, but you can take the basic principle and edit it for your needs if you like.
ip cef (you probably have this enabled anyway but hey..)
class-map VOIP-RTP
match protocol rtp audio
match protocol rtcp
class-map VOIP-SIG
match protocol SIP (if your using sip out, im guessing you are)
policy-map VOIP
class VOIP-RTP
priority (enter how much bandwidth you want to prioritise on the link, usually up to 33% of bw, you can also enter a percentage)
class VOIP-SIG
bandwidth (usually around 5% of left BW, or with a percentage if done above)
class class-default
fair
interface 0/1 (example)
service-policy output VOIP
Test this after you apply it and see if it makes a difference.
please rate helpful posts
01-11-2011 02:14 PM
Call manager automatically marks its signalling and voice traffic with cs3 and ef respectively, you can change these settings in service params.
This is obviously for outbound traffic.
Inbound should already be marked by you SP.
01-11-2011 02:20 PM
So CallManager marks it but I am looking at what should be setup in the switching and router to facilitate proper QoS and call setup.
01-11-2011 02:38 PM
QoS is a fairly broad topic so if you dont have it configured already you have allot to do, Ill work on the assumption that the lan can do without it for now, can you give me more information on the problem.
- Are the bad calls only across the trunk
- Is it all calls or only when you have a few simultaneous calls
- What else is the link used for
- Whats the topology look like
01-11-2011 02:52 PM
Here is a short run down:
1) Calls are experiencing a lot of jitter when we are calling out or calls some in....the other end of the call does not hear the same thing
2) Seems to be when multiple calls and especially when downloads are occurring from the Internet, the SIP trunk is carried across a bonded T1 that supports Inet data as well
3) Topology is as follows:
CUCM -----Switch via gig link -------Main switch via gig link -------- 2821 router via gig link -------- Inet ---- SIP Provider
The switch that the CUCM is plugged into has AutoQoS setup for our phones on all the ports that support phones but I have not put anything on the CUCM port as I am unsure of what would be best. The CUCM is setup with the trunk to the SIP Provider not the router.
01-11-2011 03:15 PM
cool, setup QoS on your routers wan connection, I very much doubt you need to set anything up between call manager and the router with them being Gb connections, i would expect the problem is at the only choke point, the WAN interface.
you could run autoqos on your internet facing wan interface and then adjust the settings it puts in the policy map, set it to something you want to reserve for just voice traffic (usually around 33%), this should setup LLQ using the priority command under the policy map, it should then protect your VoIP traffic from the downloads etc...
You should probably use locations based CAC to stop too many calls using up this BW as well.
whats the internet connection like? is it pretty fast including the latency?
If you need help with any of the commands let me know.
01-24-2011 06:52 AM
OK I am trying to implement the QoS stuff and it appears that maybe the AutoQoS is not available on Gig interfaces? I may need those commands.
01-24-2011 07:07 AM
no worries,
class-map VOIP-RTP
match protocol rtcp
class-map VOIP-SIG
policy-map VOIP
class VOIP-RTP
class VOIP-SIG
class class-default
fair
01-24-2011 08:15 AM
Thank you. I put that in and we are testing for the day and I will let you know.
