08-26-2014 04:47 AM - edited 03-16-2019 11:53 PM
Hello everybody!
Need help :)
I unstalled 88w with CME in my LAN.
CME is binded to Loopback interface.
Outer interface is connected to ISP with DHCP setting.
Outer interface is received only private IP from ISP.
So the source interface of CME is behind the double NAT.
I set up the SIP trunk to SIP provider on my 881w.
it registered successfully.
I try to call using this SIP trunk from my phone inside the LAN to the cellular.
Cellular is ringing. I take the call. and I have no audio on both ends.
here is the fragment of sh run
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol none
sip
bind control source-interface Loopback0
bind media source-interface Loopback0
registrar server
asymmetric payload full
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g726r32
codec preference 4 g726r24
codec preference 5 g726r16
codec preference 6 g723r53
codec preference 7 g723ar53
codec preference 8 g723ar63
codec preference 9 g711alaw
codec preference 10 g711ulaw
voice register global
mode cme
source-address 10.255.0.33 port 5060
max-dn 10
max-pool 5
authenticate register
timezone 32
tftp-path flash:
create profile sync 0000445942310553
camera
video
voice register dn 2
number 101
name DVG7111S
no-reg
voice register pool 2
id mac 14D6.4D89.3236
number 1 dn 2
username 101 password 101
no vad
application
service dsapp param
param callWaiting TRUE
dial-peer voice 1000 voip
service session
destination-pattern 7T
session protocol sipv2
session target dns:sipnet.ru
session transport udp
voice-class codec 1
dtmf-relay rtp-nte
sip-ua
credentials username USERNAME password 7 PASSWORD realm etc.tario.ru
authentication username 1984129 password 7 PASSWORD realm etc.tario.ru
nat symmetric role active
no remote-party-id
max-forwards 10
retry invite 3
retry response 3
retry bye 3
retry cancel 3
retry register 3
timers trying 1000
timers connect 100
timers register 150
registrar dns:sipnet.ru:5060 expires 3600
sip-server dns:sipnet.ru
no suspend-resume
connection-reuse
host-registrar
During the debug I received:
SIP: Trying to parse unsupported attribute at media level
IPNAT SIP SDP: Trying to parse unsupported attribute at media level
please help me to solve the problem :)
09-02-2014 11:35 PM
It does not like something in the sdp portion(media) of the SIP message.
run debug ccsip mess to see the sip message that is triggering this - look at the sdp portion of the message.
If the message is large (>1500 bytes) and you are using UDP it appears this will truncate the message since it is larger than the MTU, try TCP if this is the case. I would also pare down your codec list to be just g711u, g711a and see if that helps - can't say for sure without seeing the sdp that triggered this.
09-03-2014 06:27 AM
hello!
thanx for a help.
have changed session protocol from udp to tcp. reduces voice class to two 711 codecs
no effect
here is the debug screen.
h33#deb ccsip mess
Sep 3 13:25:15.992: %ENVMON-3-FAN_FAILED: Fan is malfunctioning
SIP Call messages tracing is enabled
h33#
Sep 3 13:25:34.297: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:79035964926@sipnet.ru:5060 SIP/2.0
Via: SIP/2.0/TCP 10.255.0.33:5060;branch=z9hG4bK20EAD03
To: <sip:79035964926@sipnet.ru>
Date: Wed, 03 Sep 2014 13:25:34 GMT
Call-ID: 9E794ED4-32A411E4-8536EE8F-6D59C4C9@10.255.0.33
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 2529946392-0849613284-2234642063-1834599625
User-Agent: Cisco-SIPGateway/IOS-15.3.3.M3
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 10
Timestamp: 1409750734
Contact: <sip:200@10.255.0.33:5060;transport=tcp>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 311
v=0
o=CiscoSystemsSIP-GW-UserAgent 6970 1840 IN IP4 10.255.0.33
s=SIP Call
c=IN IP4 10.255.0.33
t=0 0
m=audio 16420 RTP/AVP 18 101 19
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
a=direction:active
Sep 3 13:25:34.301: //5453/96CBEB188531/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 10.255.0.33:5060;branch=z9hG4bK20EAD03;received=185.19.21.230
CSeq: 101 INVITE
Server: CommuniGatePro/6.0.10i
Content-Length: 0
Sep 3 13:25:34.501: //5453/96CBEB188531/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Authentication required
To: <sip:79035964926@sipnet.ru>;tag=04A3F0DB
CSeq: 101 INVITE
WWW-Authenticate: Digest realm="etc.tario.ru",nonce="CEE07EBED4C5B039A9BB",opaque="opaq",qop="auth",algorithm=MD5
Content-Length: 0
Sep 3 13:25:34.505: //5453/96CBEB188531/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:79035964926@sipnet.ru:5060 SIP/2.0
Max-Forwards: 10
CSeq: 101 ACK
Content-Length: 0
Sep 3 13:25:34.513: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 10.255.0.33:5060;branch=z9hG4bK20EB18DE
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 10
Expires: 180
Authorization: Digest username="1984129",realm="etc.tario.ru",uri="sip:79035964926@sipnet.ru:5060",response="3dd1d64c350b925293973b9e5f0569a2",nonce="CEE07EBED4C5B039A9BB",opaque="opaq",cnonce="5E492828",qop=auth,algorithm=MD5,nc=00000001
Content-Length: 311
v=0
s=SIP Call
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
a=direction:active
Sep 3 13:25:34.517: //5453/96CBEB188531/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 10.255.0.33:5060;branch=z9hG4bK20EB18DE;received=185.19.21.230
CSeq: 102 INVITE
Content-Length: 0
Sep 3 13:25:42.017: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Sep 3 13:25:44.177: //5453/96CBEB188531/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
Record-Route: <sip:22059943-192.168.40.76.dialog.cgatepro;lr>
Record-Route: <sip:192.168.40.76:5060;lr>
Record-Route: <sip:212.53.40.40:5060;transport=tcp;lr>
To: <sip:79035964926@sipnet.ru>;tag=7C5ABB4F-188722-7B58386C_kmbdcto-EF93
CSeq: 102 INVITE
Contact: <sip:signode-188722-7B58386C_kmbdcto-EF93@212.53.40.40>
Supported: 100rel,timer,replaces,histinfo,precondition
User-Agent: CommuniGatePro-callLeg/6.0.10i
Allow: INVITE,ACK,BYE,CANCEL,OPTIONS,INFO,MESSAGE,SUBSCRIBE,NOTIFY,PRACK,UPDATE,REFER
Content-Length: 356
v=0
o=CGPLeg188722 1596047711 798023856 IN IP4 212.53.40.76
s=-
c=IN IP4 212.53.40.76
t=0 0
m=audio 31782 RTP/AVP 18 101
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
a=ptime:20
a=ice-pwd:91304E78B98ACE376F04F8CF
a=ice-ufrag:pf7845678
a=silenceSupp:off - - - -
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
Sep 3 13:25:49.061: //5453/96CBEB188531/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Session-Expires: 10800;refresher=uas
Content-Length: 356
v=0
o=CGPLeg188722 1596047711 798023857 IN IP4 212.53.40.76
s=-
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
a=ptime:20
Sep 3 13:25:49.069: //5453/96CBEB188531/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:signode-188722-7B58386C_kmbdcto-EF93@212.53.40.40 SIP/2.0
Via: SIP/2.0/TCP 10.255.0.33:5060;branch=z9hG4bK20EC7D0
Route: <sip:212.53.40.40:5060;transport=tcp;lr>,<sip:192.168.40.76:5060;lr>,<sip:22059943-192.168.40.76.dialog.cgatepro;lr>
Max-Forwards: 10
CSeq: 102 ACK
Content-Length: 0
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
Sep 3 13:26:03.942: //5453/96CBEB188531/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:signode-188722-7B58386C_kmbdcto-EF93@212.53.40.40 SIP/2.0
Via: SIP/2.0/TCP 10.255.0.33:5060;branch=z9hG4bK20ED4C4
Max-Forwards: 10
Timestamp: 1409750763
CSeq: 103 BYE
Authorization: Digest username="1984129",realm="etc.tario.ru",uri="sip:signode-188722-7B58386C_kmbdcto-EF93@212.53.40.40",response="6854cf0be0968006afefbac774552400",nonce="CEE07EBED4C5B039A9BB",opaque="opaq",cnonce="7402EB35",qop=auth,algorithm=MD5,nc=00000002
Reason: Q.850;cause=16
P-RTP-Stat: PS=977,OS=19540,PR=0,OR=0,PL=0,JI=0,LA=0,DU=14
Content-Length: 0
Sep 3 13:26:03.950: //5453/96CBEB188531/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
Via: SIP/2.0/TCP 10.255.0.33:5060;branch=z9hG4bK20ED4C4;received=185.19.21.230
CSeq: 103 BYE
Content-Length: 0
first part - when my phone is calling
second - my cellular is ringing
third - I pick up the phone
09-03-2014 06:36 AM
Hi.
Try to change your register pool 2 as follow
codec g711ulaw
Also try to change your DP 1000 with codec g711ulaw only
no voice-class codec 1
codec g711ulaw
After these changes, please send again a debug ccsip messages
Carlo
09-03-2014 06:47 AM
done.
still no audio
and sorry for a mistake
1st portion - from dialing till cellular ringing
2nd portion - from picking up the cellular till hearing no audio
3rd portion - from ending the call
4th portion - something after the whole call
h33#sh deb
CCSIP SPI: SIP Call Message tracing is enabled (filter is OFF)
h33#
Sep 3 13:41:56.861: //5465/E0698F10853F/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/TCP 10.255.0.33:5060;branch=z9hG4bK20FE1D22
Date: Wed, 03 Sep 2014 13:41:56 GMT
Call-ID: E8228B8D-32A611E4-8544EE8F-6D59C4C9@10.255.0.33
Min-SE: 1800
Cisco-Guid: 3765014288-0849744356-2235559567-1834599625
CSeq: 101 INVITE
Max-Forwards: 10
Timestamp: 1409751716
Expires: 180
Content-Length: 288
v=0
o=CiscoSystemsSIP-GW-UserAgent 4486 3464 IN IP4 10.255.0.33
s=SIP Call
t=0 0
m=audio 16424 RTP/AVP 0 101 19
a=rtpmap:0 PCMU/8000
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
a=direction:active
Sep 3 13:41:56.865: //5465/E0698F10853F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 10.255.0.33:5060;branch=z9hG4bK20FE1D22;received=185.19.21.230
CSeq: 101 INVITE
Content-Length: 0
Sep 3 13:41:56.873: //5465/E0698F10853F/SIP/Msg/ccsipDisplayMsg:
Received:
To: <sip:79035964926@sipnet.ru>;tag=8BF4A760
CSeq: 101 INVITE
WWW-Authenticate: Digest realm="etc.tario.ru",nonce="8BBB6E2C0D9589C38583",opaque="opaq",qop="auth",algorithm=MD5
Content-Length: 0
Sep 3 13:41:56.877: //5465/E0698F10853F/SIP/Msg/ccsipDisplayMsg:
Sent:
Max-Forwards: 10
CSeq: 101 ACK
Content-Length: 0
Sent:
Via: SIP/2.0/TCP 10.255.0.33:5060;branch=z9hG4bK20FF2011
Min-SE: 1800
CSeq: 102 INVITE
Max-Forwards: 10
Expires: 180
Authorization: Digest username="1984129",realm="etc.tario.ru",uri="sip:79035964926@sipnet.ru:5060",response="a67b0a23d2682f6845d5efd55b6f7630",nonce="8BBB6E2C0D9589C38583",opaque="opaq",cnonce="73329928",qop=auth,algorithm=MD5,nc=00000001
Content-Length: 288
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=rtpmap:19 CN/8000
a=ptime:20
a=direction:active
Sep 3 13:41:56.905: //5465/E0698F10853F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/TCP 10.255.0.33:5060;branch=z9hG4bK20FF2011;received=185.19.21.230
CSeq: 102 INVITE
Content-Length: 0
Sep 3 13:42:00.997: //5465/E0698F10853F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
Record-Route: <sip:23270408-192.168.40.72.dialog.cgatepro;lr>
Record-Route: <sip:192.168.40.72:5060;lr>
To: <sip:79035964926@sipnet.ru>;tag=04635E58-863704-F70B7D36_kmbdctk-EF93
CSeq: 102 INVITE
Contact: <sip:signode-863704-F70B7D36_kmbdctk-EF93@212.53.40.40>
Content-Length: 333
v=0
o=CGPLeg863704 1376140245 688070123 IN IP4 212.53.40.72
s=-
c=IN IP4 212.53.40.72
t=0 0
m=audio 32272 RTP/AVP 0 101
a=fmtp:101 0-15
a=sendrecv
a=ptime:20
a=ice-pwd:EA6EBCC9AA5AB6FDE2773775
a=ice-ufrag:pf8286013
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
Sep 3 13:42:06.529: //5465/E0698F10853F/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 102 INVITE
Content-Length: 333
v=0
o=CGPLeg863704 1376140245 688070124 IN IP4 212.53.40.72
s=-
t=0 0
a=fmtp:101 0-15
a=sendrecv
a=ptime:20
Sep 3 13:42:06.541: //5465/E0698F10853F/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:signode-863704-F70B7D36_kmbdctk-EF93@212.53.40.40 SIP/2.0
Via: SIP/2.0/TCP 10.255.0.33:5060;branch=z9hG4bK21002618
Route: <sip:212.53.40.40:5060;transport=tcp;lr>,<sip:192.168.40.72:5060;lr>,<sip:23270408-192.168.40.72.dialog.cgatepro;lr>
Max-Forwards: 10
CSeq: 102 ACK
Content-Length: 0
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
h33#
Sep 3 13:42:12.018: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
Sep 3 13:42:15.762: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:200@10.255.0.33:5060;transport=tcp SIP/2.0
Via: SIP/2.0/TCP 212.53.40.40:5060;branch=z9hG4bK400554-kmbdctk;cgp=etc.tario.ru;rport
Max-Forwards: 70
From: <sip:79035964926@sipnet.ru>;tag=04635E58-863704-F70B7D36_kmbdctk-EF93
To: <sip:200@sipnet.ru>;tag=2A6E4F2C-23C1
CSeq: 1 BYE
Reason: SIP;cause=200;text="bridge closed"
Content-Length: 0
Sep 3 13:42:15.774: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
Date: Wed, 03 Sep 2014 13:42:15 GMT
Server: Cisco-SIPGateway/IOS-15.3.3.M3
CSeq: 1 BYE
P-RTP-Stat: PS=733,OS=117280,PR=0,OR=0,PL=0,JI=0,LA=0,DU=9
Content-Length: 0
and seconds later I see:
REGISTER sip:sipnet.ru:5060 SIP/2.0
Via: SIP/2.0/UDP 10.255.0.33:5060;branch=z9hG4bK210193
Date: Wed, 03 Sep 2014 13:44:22 GMT
Call-ID: 6323A6E9-2C3411E4-8003EE8F-6D59C4C9
Max-Forwards: 10
Timestamp: 1409751862
CSeq: 7892 REGISTER
Contact: <sip:200@10.255.0.33:5060>
Expires: 3600
Supported: path
Content-Length: 0
Sep 3 13:44:22.089: //5466/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
Via: SIP/2.0/UDP 10.255.0.33:5060;branch=z9hG4bK210193;received=185.19.21.230
Path: <sip:udp-185.19.21.230-10438S212.53.40.40-5060.nat.cgatepro;lr>
To: <sip:200@sipnet.ru>;tag=1A9A69B8
CSeq: 7892 REGISTER
WWW-Authenticate: Digest realm="etc.tario.ru",nonce="B81C71A06C188B107AC2",opaque="opaq",qop="auth",algorithm=MD5
Content-Length: 0
Sep 3 13:44:22.089: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.255.0.33:5060;branch=z9hG4bK21022D8
Max-Forwards: 10
CSeq: 7893 REGISTER
Expires: 3600
Authorization: Digest username="1984129",realm="etc.tario.ru",uri="sip:sipnet.ru:5060",response="a507544131b4c04ae00a7d75c027bbb0",nonce="B81C71A06C188B107AC2",opaque="opaq",cnonce="12F01C1A",qop=auth,algorithm=MD5,nc=00000001
Content-Length: 0
Sep 3 13:44:22.097: //5466/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 403 you do not have the required access right
Via: SIP/2.0/UDP 10.255.0.33:5060;branch=z9hG4bK21022D8;received=185.19.21.230
To: <sip:200@sipnet.ru>;tag=71B722EC
CSeq: 7893 REGISTER
Content-Length: 0
09-04-2014 05:57 AM
It appears that this sdp is causing the message:
v=0
s=-
t=0 0
a=fmtp:18 annexb=no
a=fmtp:101 0-15
a=sendrecv
a=ptime:20
I suspect the 2 ice attribute may be causing the message you see. See rfc5245 15.4.
Not sure if CME supports this - maybe a good question for TAC.
Alos this indicates that g729 is to be used - add that back to your codec list
