08-27-2019 10:05 AM
Hi All,
We're just having issue with SIP trunk, when we try to do DOD via PSTN, and when call connected, sometime voice is silent for 1 or 2 seconds, caller from internal always hear what external talk, but external sometimes can't hear voice from internal for 1 or 2 second,
Hope you guys give me recommendations such as what debug should I do, or another thing to get better log
08-28-2019 03:23 AM
Hello Seski,
Is the call flow like below.
Phone >> SIP>> CUCM>>SIP>>Gateway>>ITSP SIP provider >>PSTN number
or
Phone >> SIP>> CUCM>>SIP>>Gateway>>E1 PRI >>PSTN number
If the call flow involved ITSP provider then you will have to take packet capture from Phone and Gateway.
If the call flow involved E1 Controller , you need to verify if there is any issue with Controller like slip sec and crc error, then you will have to take packet capture from phone , gateway sip leg and PCM capture for the ISDN leg.
08-28-2019 04:01 AM
Hi Hari Prasad,
Thx for replying, topology is this one
What do you mean by capture packet, do you mean with wireshark? do we need do some debug etc?
Thx a lot
08-28-2019 05:00 AM
Hello Seski,
With debugs you can trace the call only.
To troubleshoot the one way audio or voice quality issue , packet capture is the best option.
Please follow below URL to take capture
1- Packet capture from Phone
https://community.cisco.com/t5/collaboration-voice-and-video/collecting-a-packet-capture-from-a-cisco-ip-phone/ta-p/3119480
https://www.uccollabing.com/how-to-collect-packet-capture-from-cisco-ip-phone/
2- Packet capture from Gateway-
https://www.cisco.com/c/en/us/support/docs/voice/h323/116078-technologies-technote-commandrefe.html
Once you done with packet capture , open the pcap file using wireshark to check the issue or attachd pacp file here to check the issue.
