SIP TRUNK issues (Siemens OpenScape)
All,
Could someone help me understand the following errors?
Does anyone have any experience of establishment (setup) of SIP TRUNK with (Siemens OpenScape)?
I'm using the SME. CUBE is required?
I'm trying to make a call on an IP phone (CUCM) to an IP phone (Siemens OpenScape) through a SIP TRUNK, and this is not working.
The complete LOG is attached.
Error:
16:45:09.305 |//SIP/Stack/Error/0x0/DROPPING unregistered header Timestamp: 1348602309|1,100,71,1.1^*^*
16:45:09.307 |DbMobility: can't find remdest 2121011534 in map|*^*^*
16:45:09.310 |DbMobility: can't find remdest 6520 in map|*^*^*
16:45:09.315 |//SIP/Stack/Error/0x0/Invalid message platform data in the container|1,100,71,1.1^*^*
16:45:09.327 |!!ERROR!! -ConnectionManager- wait_AuDisconnectRequest :CI NOT FOUND IN TABLE,CI
16:45:09.327 |//SIP/SIPCdpc(1,74,7)/ci=25695671/ccbId=8/scbId=0/addTransparencyInfo: Transparency info is NULL.  Not attaching anything.|1,100,230,1.12^172.31.253.70^*
16:45:09.332 |//SIP/Stack/Error/0x0/Could not find conn holder for addr=52.200.200.1|
Thanks!
Luciane de Medeiros
12 Replies 12
Chrysostomos_CY
Level 5
Level 5
Do you have dial peers pointed to siemens ip?
dial-peer voice 100 voip
description to siemens**
preference 1
destination-pattern (pattern for siemens extensions)
session protocol sipv2
session target ipv4: (siemens ip)
voice class codec 1
incoming called number .
dtmf-relay rtp-nte
no vad
Do you allow connections
voice service voip
allow-connections sip to h323
allow-connections sip to sip
What do you have..cme or cucm..
if is cucm then you dont need the above
you will send the calls to siemens throught sip trunk and route patterns
Please rate all useful posts Regards Chrysostomos ""The Most Successful People Are Those Who Are Good At Plan B""
Sorry
i just saw that is cucm
So sip trunk with siemens/route pattern for siemens extension pointed to the sip trunk(route list)/
Incoming calls from siemens are ok
Hi Chrys,
I think I've met the requirements. I am sending the gateway configuration.
Luciane de Medeiros
Can you describe the call flow?
What is the ip of siemens?
What is the result with incoming calls from siemens?
In ALL dial peer put no vad.Vd is very bad
Hi Chrys,
Call Flow:
Source:
Number - 2121011534
IP - 50.200.200.1 (Gateway)
Destination:
Number - 6520 or 6519
IP - 50.200.200.5 (SME) --> 172.31.253.70 (Trunk SIP Siemens)
Still could not perform the incoming call :-(
I put "no vad" on the dial peer :-)
dial-peer voice 400 voip
description *** SIP CALLS SEDE ***
preference 1
service dsapp
destination-pattern 6...
session target ipv4:52.200.200.5
voice-class codec 1
incoming called number .T
dtmf-relay rtp-nte
no vad
I'm trying to remotely perform a test with the command "csim start 6520", but it is not working.
Luciane de Medeiros
Ayodeji Okanlawon
Please send the full CUCM sdi trace. Make sure your sure you have set the cucm traces to detailed. Also send the calling and called number
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
Hi aokanlawon,
I'll be sending the trace with the details.
Luciane de Medeiros
What protocol do you use for your terminal connection to the GW, telnet or ssh?
csim start only work if you use telnet.
Please rate all useful posts.
Response Signature
Hi Roger,
It is Telnet. ;-)
Luciane de Medeiros
Luciane,
your call flow is not clear....
is this it?
CUCM--------sip trunk---------CUBE-----Sip trunk--Siemens
Why are you using csim start? Why not a proper test call..
If you have a CUBE, send debug ccsip messages, if you dont and you have a direct CUCM sip trunk to the siemens, then you need to send cucm traces
Chrysostomos_CY
Level 5
Level 5
I am also confused
I see cme with sip dial peers to SME
What is the SME..
And then other sip dial peers for something else
Could you pls give some lights?
All,
The problem was solved after correcting the IP in the Siemens.
The IP was incorrect and the trunk was not established.
The calls are working with the settings sent.
Luciane de Medeiros
