SIP Trunk ITSP
clark white
Level 2
Level 2
I am trying to setup a new sip trunk (new connection) to ITSP, whenever i dial a PSTN number i get a fast busy tone, My ITSP says everything is OK from their end,
Can anybody refer me for step by step troubleshooting docs for such type of issue.
2 Accepted Solutions
Ok..Everything is fine on your part..Please contact your service provider...
Apr 23 12:05:10.304: //205014/0A75E4800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 500 Server Internal Error
Via: SIP/2.0/UDP 10.240.23.235:5060;branch=z9hG4bK9525F2;rport=61288
Call-ID: E170335D-AB4411E2-A1B8F940-B2641F7D@10.240.23.235
To: <24489269>;tag=jcnbveen
CSeq: 101 INVITE
Content-Length: 0
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Question 1, yes your config is correct..
Question 3, It is the recommended solution to use sip trunk to the CUBE rather than h323...
19 Replies 19
Ayodeji Okanlawon
Clark,
You start by looking at the sip traces..
debug ccsip messages
You can send here and we can look at it.include calling and called number
Hello
here is the attached
calling number 8243
called number 244892969
What or who is this IP ? 10.230.0.26
This device is sending internal error..
Received:
Via: SIP/2.0/UDP 10.240.23.235:5060;branch=z9hG4bK8B80;rport=59611
Call-ID: 8536818-AB3211E2-A190F940-B2641F7D@10.240.23.235
To: <24489269>;tag=chkxe7ov
CSeq: 101 INVITE
Content-Length: 0
Can you send your sh run please and explain the ips in it
Attached is the sh run
1 question is it compulsory to create a SIP trunk between VG and callmanager when a SIP trunk is between VG and ITSP.
PRI SIP Server ITSP: 10.X.X.X
CallManager: 10.X.X.X
VG: 10.X.X.X
It is better to use sip to sip  set up. So yes create a sip trunk betwwen cucm and vg..and then point your route pattern to the sip trunk..
But is this a issue or issue is lying somewhere else
any configuration example to create a sip trunk between a VG and CUCM
It is easy..
Go to CUCM, device>sip trunk>add new
Add all the required parameters, device pool, inbound CSS and then specify the destination ip as the ip address of the voice gateway..The local interface...
Then configure your route p atterns to the sip trunk
Here is the attached after i changed to SIP trunk
At the moment, you have configured your inbound dial-peer from cucm to VG to use sip protocol. However you are using h323 from your CUCM to your gateway..this wont work...So you either configure a sip trunk which is better or reconfigure your gateway to use h323 on the inbound leg
dial-peer voice 10 voip
preference 1
destination-pattern .T
session protocol sipv2
session target ipv4:10.230.16.26
incoming called-number .
dtmf-relay rtp-nte
please find the attached debug,
the results are same
configure this..
voice service voip
sip-ua
early-offer forced
Test again and send debugs
there is no such command under
sip-ua
early-offer forced
It is in dial-peer should i remove from there???
also i have changed
dial-peer voice 1 voip
destination-pattern 8...
session target ipv4:10.X.X.X
no voice-class sip early-offer forced
no voice-class sip pass-thru headers
no voice-class sip pass-thru content unsupp
dtmf-relay rtp-nte
sorry its..
voice service voip
sip
early-offer forced
The result are same.please find the attached
