04-23-2013 02:30 AM - edited 03-16-2019 04:57 PM
I am trying to setup a new sip trunk (new connection) to ITSP, whenever i dial a PSTN number i get a fast busy tone, My ITSP says everything is OK from their end,
Can anybody refer me for step by step troubleshooting docs for such type of issue.
Solved! Go to Solution.
04-23-2013 05:18 AM
Ok..Everything is fine on your part..Please contact your service provider...
Apr 23 12:05:10.304: //205014/0A75E4800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 500 Server Internal Error
Via: SIP/2.0/UDP 10.240.23.235:5060;branch=z9hG4bK9525F2;rport=61288
Call-ID: E170335D-AB4411E2-A1B8F940-B2641F7D@10.240.23.235
To: <24489269>;tag=jcnbveen24489269>
CSeq: 101 INVITE
Content-Length: 0
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
04-23-2013 05:25 AM
Hello
Also I have changed the below config by adding a line in dial-peer session protocol sipv2 heading upstream to CUCM is it correct??
dial-peer voice 1 voip
destination-pattern 8...
session target ipv4:10.X.X.X
incoming called-number .
no voice-class sip early-offer forced
no voice-class sip pass-thru headers
no voice-class sip pass-thru content unsupp
dtmf-relay rtp-nte
How i shld clearify them that the problem is lying at their end by sending the below output.???
Received:
Via: SIP/2.0/UDP 10.240.2.2:5060;branch=z9hG4bK9525F2;rport=61288
Call-ID: E170335D-AB4411E2-A1B8F940-B2641F7D@10.240.2.2
CSeq: 101 INVITE
Content-Length: 0
Is it compulsory to configure CUBE when a sip trunk is configured on the VG ?????
04-23-2013 05:28 AM
Yes there device is sending 500 internal server error..Send them the traces
04-23-2013 05:30 AM
You didnt anwnsered my question 1 and 3
04-23-2013 05:49 AM
Question 1, yes your config is correct..
Question 3, It is the recommended solution to use sip trunk to the CUBE rather than h323...
