SIP Trunk license to connect Audicodes with CUCM
svryo
If I want to connect by SIP Trunk my CUCM 12.5 with an Audicodes Mediant 800B router, do I need a SIP Trunk license in the CUCM? The Audiocodes router would function as an SBC (Session Border Controller) to receive incoming and outgoing calls from Microsoft Teams to the CUCM.
Please help me and thanks in advance.
Jaime Valencia
There is no such thing as a SIP trunk license in CUCM, license is user based and the SIP trunks do not require any license in CUCM.
java
if this helps, please rate
Jaime Valencia
java
mradell
You do not need licenses to configure a SIP trunk in CUCM.
If you were using a Cisco solution for your SBC (Cisco CUBE) you would need licenses on the CUBE.
As other members commented there is no TRUNK  license in CUCM. This exist in traditional PBX and IP systems like Alcatel avaya etc..
Response Signature
