SIP trunk licenses question
raid_t
Hi there,
I have a question on SIP trunk licensing for a setup CUCM <-> CUBE <-> ITSP. Let's say I have 50 phones (users) on the LAN side.
Q1: Do I need the "CUBE-T-STD" licenses?
Q2: Let's say I need 20 active sip trunks, will that require to purchase 21 CUBE-T-STD licenses since an addition sip trunk is between cube itself and cucm?
Thanks!
T.
Jonathan Schulenberg
CUBE licenses are for each concurrent call/session connected through CUBE. Assuming CUCM and a single carrier trunk are the only two things and you need a total of 20 concurrent calls then you need 20 CUBE licenses. The STD is for non-redundant setups. You would need RED if you intend to support box-to-Box redundancy.
