SIP Trunk: Reason: Q.850;cause=47
Hello Huston,
I have a situation,
A client of mine implemented direct SIP trunk from their CUCM 8.5 to their MERA softswitch.
They set MTP required, cause doesn't work otherwise.
MTP is CallCount = 120 on each CUCM (2 of them in cluster)
We have certain number of disconnected/dropped calls from CC agents phones,
Reason: Q.850;cause=47 shows on Mera and on CUCM traces.
A strange thing I've noticed through trace is that devices are trying to locate/contact a Transcoder/MTP gateway that is no longer active, its actually deleted, and after it's not found Trace shows error.
MediaTerminationPointControl(228981) - ERROR  stationOutputRegisterReject TCPPid = [1.100.9.3131273]|1,100,50,1.246492299^192.168.4.37^vg-beo-old
|MediaTerminationPointControl(228647)::processMediaTerminationPointTspErr  ERROR  for device= VG-BEO-OLD  -- Tsp Error: Device Does not exist in Database|1,100,50,1.246406444^192.168.4.37^vg-beo-old
12:57:01.925 |MediaTerminationPointControl(228647) - ERROR  stationOutputRegisterReject TCPPid = [1.100.9.3129238]|1,100,50,1.246406444^192.168.4.37^vg-beo-old
12:57:01.925 |StationInit:   TCPPid = [1.100.9.3129238] StationCloseReq received: output|1,100,50,1.246406444^192.168.4.37^vg-beo-old
12:57:01.925 |Closing Station connection DeviceName=vg-beo-old, TCPPid = [1.100.9.3129238], IPAddr=192.168.4.37, Port=19275, Device Controller=[1,122,228647]|1,100,50,1.246406444^192.168.4.37^vg-beo-old
12:57:01.925 |MediaTerminationPointControl(228647)::shutting_down_MediaTerminationPointStopConf - Device - VG-BEO-OLD - Un-registered|1,100,50,1.246406444^192.168.4.37^vg-beo-old
Could this error generate drop of calls?
Does someone has any suggestions, what should I do regarding dropped calls and that error for trying to contact deleted Transcoder/MTP?
Any help is greatly appreciated!
Thanx
V
5 Replies 5
did you try creating new MRGL with available MTP on the top of the list and assign it to SIP Trunk?
also, can you check the service parameter " Fail Call over SIP Trunk if MTP allocation fails" ?
~SS
//Suresh Please rate all the useful posts.
Hello Suresh,
Thank you for your answer. Why would I need another MRGL?
For the deleted transcoder, it was bound to some long forgotten profile, so it should be fine regarding transcoder and trying to connect with it.
I left some detailed traces to work over weekend, so I'll check them after work.
Cheers
V
stschm0012
Hi V,
first of all Q.850;cause 47 means "Resource unavailable/ unspecified".
Could you provide more information on how the MTP is registered?
E.g. IOS Enhanced SW MTP
Did you checked the MRG's and MRGL's?
Did you a restart for the affected phones?
It could appear as such, but i would describe it as lost call. Because the call never established.
Regards.
Hi Steffen,
MTP is CUCM software one, and its in the MRGL, 2 CUCMs actually,
Besides never established calls, there are dropped calls.
Didn't restart affected phones, because calls are dropped randomly, don't know if there are particular phones affected.
What can I do, to uncheck MTP Required and to have calls go to agents?
I hate when something is configured and I am not aware of it, until problem comes up.
Thanx
V
It was codec of course... They haven't match codec on both sides of SIP trunk.
Thanx everyone
Cheers
V
