SIP Trunk /// SIP/2.0 480 No Routes Found
Leonardo Santana
Hello
I trying to make outbound calls to a sip trunk but when i dial a receive an fast busy tone, in debug ccsip messages i receive this disconnect cause:
Follow attached the output of the debug.
I already have configured the Route Groups - Route List and Route Patterns and the dial-peers on the gayeway
Inbound calls are working
Leonardo Santana
*** Rate All Helpful Responses***
6 Replies 6
Chris Deren
What is 172.26.154.70 in your flow? Is this CUBE? If so can you post the config?
Chris
Is the SIP Proxy of the ISTP
sure is attached
voice-card 0
dsp services dspfarm
voice call send-alert
voice call carrier capacity active
voice rtp send-recv
voice service voip
ip address trusted list
  ipv4 10.55.8.194 255.255.255.255
  ipv4 10.55.8.193 255.255.255.255
  ipv4 172.26.154.70 255.255.255.255
  ipv4 10.0.140.0 255.255.255.0
address-hiding
mode border-element
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  bind control source-interface GigabitEthernet0/0
  bind media source-interface GigabitEthernet0/0
  header-passing
  error-passthru
  no update-callerid
  early-offer forced
  midcall-signaling passthru
voice class codec 1
codec preference 1 g729br8
codec preference 2 g729r8
codec preference 3 g711ulaw
codec preference 4 g711alaw
voice class sip-profiles 1
request INVITE sip-header Diversion modify "<>)" "<1123954000>"
voice translation-rule 1
rule 1 /^00800/ /0800/
rule 2 /^00300/ /0300/
rule 3 /^000../ /0012/
rule 4 /^00../ /012/
rule 5 /^0/ //
voice translation-rule 2
rule 1 /4.../ /1123954000/
voice translation-rule 3
rule 1 /^2395/ //
voice translation-profile InboundPSTN
translate called 3
voice translation-profile PSTNAccess
translate calling 2
translate called 1
--More--                           !
license udi pid CISCO2901/K9 sn FTX160383B5
hw-module pvdm 0/0
hw-module pvdm 0/1
username admin privilege 15 secret 5 $1$TUbA$CRVsOgpFBREmxhncIqkOi0
redundancy
ip ssh version 2
translation-rule 3
interface Embedded-Service-Engine0/0
no ip address
shutdown
description ----------------[SIP-TRUNK-ALGAR]
ip address 10.55.52.25 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/1
description Voice Network
ip address 10.0.1.65 255.255.248.0
duplex auto
speed auto
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.0.1.65
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 10.0.1.254
ip route 10.55.52.21 255.255.255.255 10.55.52.26
ip route 10.55.52.22 255.255.255.255 10.55.52.26
ip route 172.26.154.70 255.255.255.255 10.55.52.26
control-plane
mgcp profile default
sccp local GigabitEthernet0/1
sccp ccm 10.0.1.62 identifier 1 priority 1 version 7.0
sccp
sccp ccm group 1
description -------[ALMAP_CCM_CG]
bind interface GigabitEthernet0/1
associate ccm 1 priority 1
associate profile 30 register MTPVGW01
associate profile 20 register CFBVGW01
associate profile 10 register XCODEVGW01
dspfarm profile 10 transcode
codec g729r8
codec g729br8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 10
associate application SCCP
dspfarm profile 20 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
--More--                            codec g729br8
maximum sessions 4
dspfarm profile 30 mtp
codec pass-through
codec g711ulaw
maximum sessions hardware 30
maximum sessions software 60
dial-peer voice 101 voip
description -------------[IN/OUT DDRs CUCM]
translation-profile outgoing InboundPSTN
preference 1
destination-pattern 23954[0-4].
session target ipv4:10.0.1.62
incoming called-number .T
voice-class codec 1
voice-class sip profiles 1
dtmf-relay rtp-nte
fax-relay ecm disable
no fax-relay sg3-to-g3
fax protocol pass-through g711ulaw
dial-peer voice 11 voip
description -------------[SERVICOS]
translation-profile outgoing PSTNAccess
destination-pattern 01..$
progress_ind setup enable 3
modem passthrough nse codec g711ulaw
session protocol sipv2
session target ipv4:172.26.154.70
voice-class codec 1
dtmf-relay sip-notify
fax rate disable
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
icpif 50
no vad
dial-peer voice 12 voip
description -------------[LOCAL-FIXO]
destination-pattern 0[2-5].......
--More--                            session target ipv4:172.26.154.70
voice-class codec 1
fax rate disable
icpif 50
no vad
dial-peer voice 13 voip
description -------------[LOCAL-CEL]
destination-pattern 0[6-9].......
voice-class codec 1
fax rate disable
icpif 50
no vad
dial-peer voice 14 voip
description -------------[DDD-LOCAL]
destination-pattern 00[1-9][1-9][2-5].......
voice-class codec 1
fax rate disable
icpif 50
no vad
dial-peer voice 15 voip
description -------------[DDD-CEL]
destination-pattern 00[1-9][1-9][6-9].......
modem passthrough nse codec g711alaw
--More--                            dtmf-relay sip-notify
fax rate disable
icpif 50
no vad
dial-peer voice 16 voip
description -------------[DDI]
destination-pattern 000.T
fax rate disable
icpif 50
no vad
dial-peer voice 17 voip
description -------------[GRATUITAS]
destination-pattern 00800T
voice-class codec 1
fax rate disable
icpif 50
no vad
dial-peer voice 18 voip
description -------------[0300]
destination-pattern 00300T
voice-class codec 1
fax rate disable
--More--                            fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
icpif 50
no vad
sip-ua
retry invite 2
retry register 10
timers connect 100
registrar ipv4:172.26.154.70 expires 3600
sip-server ipv4:172.26.154.70:5060
reason-header override
connection-reuse
host-registrar
gatekeeper
shutdown
telephony-service
srst mode auto-provision all
srst ephone description SRST Phone  : Apr 26 2012 18:41:05
srst dn line-mode dual
max-ephones 25
max-dn 25
ip source-address 10.0.140.2 port 2000
max-conferences 8 gain -6
transfer-system full-consult
banner login ^CCCC
*                           WARNING                            *
*  "Unauthorized access to this site is strictly prohibited"   *
^C
banner motd ^CCCCCCC
*                          ALMAP                     *
--More--                           *                                   *
*    Hostname:       ALMAPVGW01                                *
*    Model:          CISCO2901                                 *
*    Serial:         FTX160383B5                               *
*                   C i s c o  S y s t e m s                   *
* =====> Unauthorized use of this ROUTER is prohibited <====== *
^C
line con 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
logging synchronous
transport input telnet ssh
line vty 5 15
logging synchronous
scheduler allocate 20000 1000
ntp master
ntp server 10.0.1.41
ntp server 10.0.1.42
end
ALMAPVGW01#
s r          sh run
Building configuration...
Current configuration : 11901 bytes
! Last configuration change at 09:48:43 BRZ Tue May 15 2012 by admin
! NVRAM config last updated at 19:50:31 BRZ Mon May 14 2012 by admin
version 15.2
hostname ALMAPVGW01
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$FDN5$YFND0j76BYZfkL8uJY.bn1
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone BRZ -3 0
no ipv6 cef
ip domain name almapbbdo.com.br
ip name-server 10.0.1.41
ip name-server 10.0.1.42
ip cef
voice-card 0
voice rtp send-recv
voice service voip
address-hiding
--More--                            mode border-element
sip
  header-passing
  error-passthru
  no update-callerid
  early-offer forced
voice class codec 1
rule 5 /^0/ //
rule 1 /^2395/ //
translate called 3
translate calling 2
translate called 1
--More--                           !
hw-module pvdm 0/0
hw-module pvdm 0/1
redundancy
ip ssh version 2
translation-rule 3
no ip address
shutdown
duplex auto
speed auto
duplex auto
speed auto
ip http server
--More--                           ip http timeout-policy idle 60 life 86400 requests 10000
control-plane
sccp
sccp ccm group 1
codec g729r8
codec g729br8
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 10
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
maximum sessions 4
codec pass-through
codec g711ulaw
preference 1
voice-class codec 1
dtmf-relay rtp-nte
voice-class codec 1
fax rate disable
icpif 50
no vad
voice-class codec 1
fax rate disable
icpif 50
no vad
voice-class codec 1
fax rate disable
icpif 50
no vad
voice-class codec 1
fax rate disable
icpif 50
no vad
fax rate disable
icpif 50
no vad
fax rate disable
icpif 50
no vad
voice-class codec 1
fax rate disable
icpif 50
no vad
voice-class codec 1
fax rate disable
icpif 50
no vad
sip-ua
retry invite 2
retry register 10
timers connect 100
connection-reuse
host-registrar
gatekeeper
shutdown
telephony-service
max-ephones 25
max-dn 25
Leonardo Santana
The message is coming from them, so either the number you are sending 55628226 is not correct, or they do not know how to route it. If you are confident this is proper number you will need to contact your provider.
Chris
Is is the correct number Chris!
Could IP Routing the source of the problem? Inside my network i cannot ping the SIP Proxy, inside the gateway im able to ping.
Leonardo Santana
Chris after i add one deafult route to gw the debug ccsip messages change:
May 15 13:38:25.727: //1145/0000F54B3700/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:55628226@172.26.154.70:5060 SIP/2.0
Via: SIP/2.0/UDP 10.55.52.25:5060;branch=z9hG4bK3E1838
Remote-Party-ID: <23954000>;party=calling;screen=yes;privacy=off
To: <55628226>
Date: Tue, 15 May 2012 13:38:25 GMT
Call-ID: 14E39213-9DCA11E1-8554E98E-98661DE@10.55.52.25
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0000062795-1767645691-0922775297-0167808024
User-Agent: Cisco-SIPGateway/IOS-15.2(1)T1,
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1337089105
Contact: <23954000>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 188
v=0
o=CiscoSystemsSIP-GW-UserAgent 8275 9967 IN IP4 10.55.52.25
s=SIP Call
c=IN IP4 10.55.52.25
t=0 0
m=audio 22990 RTP/AVP 0
a=rtpmap:0 PCMU/8000
a=ptime:20
May 15 13:38:26.227: //1145/0000F54B3700/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <55628226>
Date: Tue, 15 May 2012 13:38:26 GMT
Min-SE:  1800
User-Agent: C
ALMAPVGW01#isco-SIPGateway/IOS-15.2(1)T1,
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1337089106
Contact: <23954000>
Expires: 180
Content-Length: 188
v=0
s=SIP Call
t=0 0
a=ptime:20
May 15 13:38:27.227: //1145/0000F54B3700/SIP/Msg/ccsipDisplayMsg:
Sent:
To: <55628226>
Date: Tue, 15 May 2012 13:38:27 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1337089107
Contact: <23954000>
Expires: 180
Content-Length: 188
v=0
s=SIP Call
t=0 0
a=ptime:20
ALMAPVGW01#
May 15 13:38:29.227: //1145/0000F54B3700/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x319F7D58
State of The Call        : STATE_DEAD
TCP Sockets Used         : NO
Calling Number           : 23954000
Called Number            : 55628226
Source IP Address (Sig  ): 10.55.52.25
Destn SIP Req Addr:Port  : 172.26.154.70:5060
Destn SIP Resp Addr:Port : 172.26.154.70:5060
Destination Name         : 172.26.154.70
ALMAPVGW01#
May 15 13:38:29.227: //1145/0000F54B3700/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream             : 1
Negotiated Codec         : No Codec
Negotiated Codec Bytes   : 0
Nego. Codec payload      : 255 (tx), 255 (rx)
Negotiated Dtmf-relay    : 0
Dtmf-relay Payload       : 0 (tx), 0 (rx)
Source IP Address (Media): 10.55.52.25
Source IP Port    (Media): 22990
Destn  IP Address (Media):  -
Destn  IP Port    (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC)    : 102
Disconnect Cause (SIP)   : 408
_________________________________
IP Route
ip route 0.0.0.0 0.0.0.0 172.26.154.70
ip route 10.0.140.0 255.255.255.0 10.0.1.254
Leonardo Santana
Now the message does not make it to the provider at all, you are sending 3 Invites and then it times out.
Since you got a rejection from them, I would definitely give them a call and troubleshoot with them on the line.
Chris
