SIP Trunk to Broadsoft
i am new at Cisco IP Telephony. I have a 2921 CME 9.1.
I would like to configure a SIP Trunk to Broadsoft, but i don't know where i could find information for doing this?.. what do i need to configure?..
i have created a SIP Trunk to another CME without problem, this works great, and i have replicated that sip trunk config trying to create the sip trunk to broadsoft but it didn't work..
Hope somebody give the clues for this,
regards
Ok,
Everything looks okay..You are getting 604 from broadsoft..Looks like they are unable to route the dialled number,,,
Received:
SIP/2.0 604 Does not exist anywhere
Via:SIP/2.0/UDP 172.16.163.2:5060;branch=z9hG4bK5EF18C2
To:<1868>;tag=819031417-1365024129334
Call-ID:646DABB7-9BDB11E2-872E92A8-E092A3AB@172.16.163.2
CSeq:101 INVITE
Content-Length:0
Received:
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
13 Replies 13
Anas Abueideh
Level 9
Level 9
Hi Juan,
is you provider required credentials. you need the following config
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol cisco
sip
  bind control source-interface Loopback
  bind media source-interface Loopback
sip-ua
credentials username xxxxxxxxxxx password 7
xxxxxxxxxxx realm sip.voip-unlimited.net
xxxxxxxxxxx
password 7
xxxxxxxxxxx
authentication username xxxxxxxxx password 7 xxxxxxxxx realm xxx.xxxxxxx.xxx
calling-info pstn-to-sip from number set xxxxxxxxxx
retry register 10
timers register 1000
mwi-server ipv4:192.168.0.159 expires 3600 port 5060 transport udp unsolicited
registrar
xxx.xxxxxxx.xxx
expires 60
dial-peer voice 100 voip
    destination-pattern 9..........
    session protocol sipv2
    session target ipv4:x.x.x.x -- Your SIP provider IP
    dtmf-relay rtp-nte
    codec g711alaw
    no vad
also find the below links
https://supportforums.cisco.com/message/3710223#3710223
https://supportforums.cisco.com/message/3305556#3305556
https://supportforums.cisco.com/message/3646952#3646952
Anas
please don't forget to rate the helpful posts
Hi Anas,
thanks for your reply,
no, my service provider doesn't need credentials,
I have configured the dial-peer and voice service voip,
The sip-au is for credentials, is that correct?., so i think my configuration is ok..
regards,
Juan,
We use Broadsoft so I may be able to help. What is not working? Did broadsoft team provide you with the ip address to use and the port number to connect to. Broadsoft most times do not use the default port 5060.  Do you have all your details correct?
Can you send your config, a description of whats failing and we can then take it from there...We may need to look at logs too
the sip-ua for credentials
Anas
Anas, broadsoft doesnt use sip-ua credentials to authenticate...
thanks for your replies,
the provider is reviewing his configuration, i think they forgot something..
i'll wait for a couple of minutes to see if they have fixed the config.. maybe the problem is not mine..
Thanks for your help,
i have this debugs output (debug ccsip all)...
regards,
sorry i forgot the configuration..
voice service voip
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
  registrar server
dial-peer voice 104 voip
destination-pattern 1...
session target ipv4:10.1.105.20
dtmf-relay rtp-nte
codec g711ulaw
i think you only need this,
regards
What is your setup like...Broadsoft ip is 10.1.105.20...What Ip do you reach broadsoft on..You are orginating invite from 172.16.163.2...
Please describe your full setup..
sorry for not mention that,
yes my cme IP is 172.16.163.2, and broadsoft is 10.1.105.20, it is a dedicated link.. i can ping 10.1.105.20 from the CME...
broadsoft is used on my company but at another country,, so we have a dedicated link for the connection..
if you need something else please let me know,
regards,
Can you send your full show run please. The question is what is the ip on your CCME that connects to 10.1.105.20..It cant be 172.16..
this is the sh run,
yes the IP that connects to broadsoft is 172.16.163.2,
as i said the connection is through a private dedicated link,
regards,
Ok,
Received:
CSeq:101 INVITE
Content-Length:0
Received:
i have to wait for them to configure it correctly,
regards,
