SIP trunk to ISP with Authentication using Cisco Call Manager
Anas Abueideh
Level 9
Level 9
Dear All,
I am trying to configure SIP trunk with authentication on Cisco call manager 6.1. I follow this url http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/security/6_0_1/secugd/secrealm.html#wp1070948
  to configure the trunk. when I try to call it make the call, after about 2 min it hanges.
I check the logs, it show me that the phone send invite message and there is not reply from the provider.
I test the account with xlite softphone and it is working correctly.
this is the blow Invite message. is one configure this before ? Thanks in advance
INVITE sip:0096XXXXXXX@sipXXXX.net:5060 SIP/2.0
Date: Wed, 29 May 2013 14:02:21 GMT
Call-Info: <sip:192.168.1.5:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, PUBLISH
From: "Anonymous" <sip:anonymous@192.168.1.5>;tag=3880a53e-8310-4653-999f-5f152437f837-22696234
Allow-Events: presence, kpml
Supported: timer,replaces
Min-SE:  1800
Remote-Party-ID: <sip:0044XXXXXXX@192.168.1.5>;party=calling;screen=yes;privacy=full
Content-Length: 0
User-Agent: Cisco-CUCM6.1
To: <sip:0096XXXXXXX@sipXXXX.net
Contact: <sip:anonymous@192.168.1.5:5060>
Expires: 180
Call-ID: 5f89c380-1a610a6c-47-501a8c0@192.168.1.5
Via: SIP/2.0/UDP 192.168.1.5:5060;branch=z9hG4bK6b286ee30b
CSeq: 101 INVITE
Session-Expires:  1800
Max-Forwards: 70
Chris Deren
CUCM does not support authentication on SIP trunks, you will need a CUBE between CUCM and ISP.
HTH,
Chris
10 Replies 10
Chris Deren
HTH,
Chris
Hi Chris,
I check the below URL
it talks about cisco authentication for sip trunks. can you advise about it
thanks in advance
Anas
Digest authentication is available on SIP stations not SIP trunks.
HTH,
Chris
Hi Chris,
thanks again for your quick response.
just to make sure, this feature is not supported on all ccm versions or just on my version 6.1 ?
regards
Anas
Correct, no current version of CUCM including 9.1 supports authentication on SIP trunks. I would doubt that will change in near future as Cisco's approach is you should use CUBE for all SIP PSTN connections.
Chris
Hi Chris,
thanks for your support
Anas
Hi, don't you know if there is some change about SIP trunks authentication on CUCM version 10 ? Thanks
  Bertrand
No change, and I don't think you should expect one any time as I doubt this is on the roadmap.
Chris
Hello All,
Could someone give me the documentation to make this on cube and if this cube is register with Webex calling  , Could it register also with the sip provider ?
BR,
Please ask your question in a separate post instead of asking it on a multiple years old post, that is marked as solved. Apart from this your question is off topic to the OP, so either way it should not have been posted in this thread.
Response Signature
