10-14-2019 07:10 AM
Hello Everyone,
I need some help in setting up SIP Trunk on CME to send and receive all calls (local, domestic & international)
here is a copy of the voice related setting that I have:
ip dhcp excluded-address 10.10.20.1 10.10.20.20
ip dhcp pool Voice
network 10.10.20.0 255.255.255.0
default-router 10.10.20.1
dns-server 8.8.8.8
option 150 ip 10.10.20.1
voice call carrier capacity active
voice service voip
ip address trusted list
ipv4 10.10.10.0 255.255.255.0
ipv4 10.10.20.0 255.255.255.0
ipv4 185.111.128.0 255.255.255.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
early-offer forced
midcall-signaling passthru
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729br8
voice class sip-profiles 1
voice translation-rule 1
rule 1 /^9\(011.*\)/ /\1/
voice translation-rule 2
rule 1 /5011/ /02037752050/
voice translation-profile SIP
translate calling 2
translate called 1
mgcp profile default
dial-peer voice 100 voip
description **** OUTBOUND CALLS to telecoms *****
translation-profile outgoing SIP
destination-pattern 9T
session protocol sipv2
session target sip-server
voice-class sip options-keepalive up-interval 100 down-interval 50 retry 6
dtmf-relay rtp-nte
codec g711alaw
no vad
authentication username user password 7 094A453809081A3738345D72 realm sip.telecoms.com
gateway
timer receive-rtp 1200
sip-ua
credentials username user password 7 01150D354B060B2A12741751 realm sip.telecoms.com
registrar dns:sip.telecoms.com expires 3600
sip-server dns:sip.telecoms.com
gatekeeper
shutdown
telephony-service
max-ephones 25
max-dn 25
ip source-address 10.10.20.1 port 2000
auto assign 1 to 25
timeouts interdigit 4
max-conferences 12 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 Oct 08 2019 04:33:05
ephone-dn 1
number 5001 no-reg primary
label PH-1
name PH-1
ephone-dn 2
number 5002 no-reg primary
label PH-2
name PH-2
ephone-dn 3
number 5003 no-reg primary
label PH-3
name PH-3
ephone-dn 4
number 5004 no-reg primary
label PH-4
name PH-4
ephone-dn 5
number 5005 no-reg primary
label PH-5
name PH-5
ephone-dn 6
number 5006 no-reg primary
label PH-6
name PH-6
ephone-dn 7
number 5007 no-reg primary
label PH-7
name PH-7
ephone-dn 8
number 5008 no-reg primary
label PH-8
name PH-8
ephone-dn 9
number 5009 no-reg primary
label PH-9
name PH-9
ephone-dn 10
number 5010 no-reg primary
label PH-10
name PH-10
ephone-dn 11
number 5011 no-reg primary
label PH-11
name PH-11
ephone-dn 12
number 5012 no-reg primary
label Meeting Room
name Meeting Room
ephone-dn 13
number 5020 no-reg primary
label SIP
name SIP
ephone 1
device-security-mode none
mac-address 000E.3857.275B
type 7945
button 1:1
ephone 2
mac-address 000E.3833.A235
type 7945
button 1:2
ephone 3
mac-address 000D.BC80.ECD0
type 7945
button 1:3
ephone 4
mac-address 000E.3888.E6DB
type 7945
button 1:5
ephone 5
mac-address 000E.3857.2975
type 7945
button 1:4
ephone 6
mac-address 000E.38E4.6766
type 7945
button 1:6
ephone 7
mac-address 000E.3888.E116
type 7945
button 1:7
ephone 8
mac-address 000D.BC50.F87B
type 7945
button 1:8
ephone 9
mac-address 0011.20B6.229D
type 7945
button 1:9
ephone 10
mac-address 0011.20B6.22B6
type 7945
button 1:10
ephone 11
mac-address 000D.BC26.1B5D
type 7945
button 1:11
ephone 12
mac-address 001A.6C7B.56AF
type 7945
button 1:12
ephone 13
mac-address 14AB.C558.0395
type CIPC
keep-conference
button 1:13
Also here is the output of show call active voice compact
<callID> A/O FAX T<sec> Codec type Peer Address IP R<ip>:<udp>
Total call-legs: 9
130380 ANS T0 g711ulaw VOIP P1012 192.168.1.83:25282
130381 ANS T0 g711ulaw VOIP P7009 192.168.1.83:25282
130382 ANS T0 g711ulaw VOIP P170001 192.168.1.83:25282
130383 ANS T0 g711ulaw VOIP Pil 192.168.1.83:25282
130384 ANS T0 g711ulaw VOIP P1012 192.168.1.83:25282
130385 ANS T0 g711ulaw VOIP P526 192.168.1.83:25282
130386 ANS T0 g711ulaw VOIP P1012 192.168.1.83:25282
130387 ANS T0 g711ulaw VOIP P606060 192.168.1.83:25282
130388 ANS T0 g711ulaw VOIP Pistat 192.168.1.83:25282
Solved! Go to Solution.
10-15-2019 03:21 PM - edited 10-15-2019 05:32 PM
You are receiving: SIP/2.0 403 Forbidden auth ID. Is username and password configured under sip-ua correct?
Here is the signaling:
++++++++++++++++++ First INVITE sent to ITSP without Authentication Info +++++++++++++++++
Oct 15 20:56:58.499: //929/243ADBAF91F4/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:12146043977@sip.bluetelecoms.com:5060 SIP/2.0 Via: SIP/2.0/UDP 37.236.146.168:5060;branch=z9hG4bK6B1621 From: "SIP" <sip:442037752050@sip.bluetelecoms.com>;tag=531A9C-1F91 To: <sip:12146043977@sip.bluetelecoms.com> Date: Tue, 15 Oct 2019 20:56:58 GMT Call-ID: 2992A82E-EEC511E9-9203DF47-51F10770@sip.bluetelecoms.com Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 3600 Cisco-Guid: 0607837103-4005892585-2448744263-1374750576 User-Agent: Cisco-SIPGateway/IOS-12.x Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 101 INVITE Max-Forwards: 70 Timestamp: 1571173018 Contact: <sip:442037752050@37.236.146.168:5060> Expires: 180 Allow-Events: telephone-event P-Asserted-Identity: "SIP" <sip:442037752050@sip.bluetelecoms.com> Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 313 v=0 o=CiscoSystemsSIP-GW-UserAgent 2620 1107 IN IP4 37.236.146.168 s=SIP Call c=IN IP4 37.236.146.168 t=0 0 m=audio 19286 RTP/AVP 8 0 18 101 c=IN IP4 37.236.146.168 a=rtpmap:8 PCMA/8000 a=rtpmap:0 PCMU/8000 a=rtpmap:18 G729/8000 a=fmtp:18 annexb=yes a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16
++++++++++++++++++ Received Proxy Authentication Required message from ITSP +++++++++++++++++
Oct 15 20:56:58.615: //929/243ADBAF91F4/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 407 Proxy Authentication Required Via: SIP/2.0/UDP 37.236.146.168:5060;branch=z9hG4bK6B1621 From: "SIP" <sip:442037752050@sip.bluetelecoms.com>;tag=531A9C-1F91 To: <sip:12146043977@sip.bluetelecoms.com>;tag=be6cf535174b54f27be086b6ef2cfa5f.1e9e Call-ID: 2992A82E-EEC511E9-9203DF47-51F10770@sip.bluetelecoms.com CSeq: 101 INVITE Proxy-Authenticate: Digest realm="sip.bluetelecoms.com", nonce="5da6381900008cef0b08383a5999f491d242321e0496da2f" server: SBC Content-Length: 0 ++++++++++++++++++ ACK sent to ITSP +++++++++++++++++ Oct 15 20:56:58.615: //929/243ADBAF91F4/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:12146043977@sip.bluetelecoms.com:5060 SIP/2.0 Via: SIP/2.0/UDP 37.236.146.168:5060;branch=z9hG4bK6B1621 From: "SIP" <sip:442037752050@sip.bluetelecoms.com>;tag=531A9C-1F91 To: <sip:12146043977@sip.bluetelecoms.com>;tag=be6cf535174b54f27be086b6ef2cfa5f.1e9e Date: Tue, 15 Oct 2019 20:56:58 GMT Call-ID: 2992A82E-EEC511E9-9203DF47-51F10770@sip.bluetelecoms.com Max-Forwards: 70 CSeq: 101 ACK Allow-Events: telephone-event Content-Length: 0 ++++++++++++++++++ Second INVITE sent to ITSP with Authentication Info +++++++++++++++++ Oct 15 20:56:58.615: //929/243ADBAF91F4/SIP/Msg/ccsipDisplayMsg: Sent: INVITE sip:12146043977@sip.bluetelecoms.com:5060 SIP/2.0 Via: SIP/2.0/UDP 37.236.146.168:5060;branch=z9hG4bK6CCFA From: "SIP" <sip:442037752050@sip.bluetelecoms.com>;tag=531A9C-1F91 To: <sip:12146043977@sip.bluetelecoms.com> Date: Tue, 15 Oct 2019 20:56:58 GMT Call-ID: 2992A82E-EEC511E9-9203DF47-51F10770@sip.bluetelecoms.com Supported: 100rel,timer,resource-priority,replaces,sdp-anat Min-SE: 3600 Cisco-Guid: 0607837103-4005892585-2448744263-1374750576 User-Agent: Cisco-SIPGateway/IOS-12.x Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER CSeq: 102 INVITE Max-Forwards: 70 Timestamp: 1571173018 Contact: <sip:442037752050@37.236.146.168:5060> Expires: 180 Allow-Events: telephone-event Proxy-Authorization: Digest username="4718367014",realm="sip.bluetelecoms.com",uri="sip:12146043977@sip.bluetelecoms.com:5060",response="17ab9913dff4daab17481048c3e050af",nonce="5da6381900008cef0b08383a5999f491d242321e0496da2f",algorithm=md5 P-Asserted-Identity: "SIP" <sip:442037752050@sip.bluetelecoms.com> Content-Type: application/sdp Content-Disposition: session;handling=required Content-Length: 313 v=0 o=CiscoSystemsSIP-GW-UserAgent 2620 1107 IN IP4 37.236.146.168 s=SIP Call c=IN IP4 37.236.146.168 t=0 0 m=audio 19286 RTP/AVP 8 0 18 101 c=IN IP4 37.236.146.168 a=rtpmap:8 PCMA/8000 a=rtpmap:0 PCMU/8000 a=rtpmap:18 G729/8000 a=fmtp:18 annexb=yes a=rtpmap:101 telephone-event/8000 a=fmtp:101 0-16
++++++++++++++++++ Received Forbidden Auth ID from ITSP +++++++++++++++++ Oct 15 20:56:58.731: //929/243ADBAF91F4/SIP/Msg/ccsipDisplayMsg: Received: SIP/2.0 403 Forbidden auth ID Via: SIP/2.0/UDP 37.236.146.168:5060;branch=z9hG4bK6CCFA From: "SIP" <sip:442037752050@sip.bluetelecoms.com>;tag=531A9C-1F91 To: <sip:12146043977@sip.bluetelecoms.com>;tag=be6cf535174b54f27be086b6ef2cfa5f.bb8c Call-ID: 2992A82E-EEC511E9-9203DF47-51F10770@sip.bluetelecoms.com CSeq: 102 INVITE server: SBC Content-Length: 0 ++++++++++++++++++ ACK sent to ITSP +++++++++++++++++ Oct 15 20:56:58.735: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg: Sent: ACK sip:12146043977@sip.bluetelecoms.com:5060 SIP/2.0 Via: SIP/2.0/UDP 37.236.146.168:5060;branch=z9hG4bK6CCFA From: "SIP" <sip:442037752050@sip.bluetelecoms.com>;tag=531A9C-1F91 To: <sip:12146043977@sip.bluetelecoms.com>;tag=be6cf535174b54f27be086b6ef2cfa5f.bb8c Date: Tue, 15 Oct 2019 20:56:58 GMT Call-ID: 2992A82E-EEC511E9-9203DF47-51F10770@sip.bluetelecoms.com Max-Forwards: 70 CSeq: 102 ACK Allow-Events: telephone-event Content-Length: 0
10-15-2019 07:11 PM
Can you try below configuration:
voice class sip-profiles 1 request INVITE sip-header From modify "sip.bluetelecoms.com" "37.236.146.168" request INVITE sip-header P-Asserted-Identity modify "sip.bluetelecoms.com" "37.236.146.168" ! dial-peer voice 100 voip voice-class sip profiles 1 !
10-15-2019 07:41 PM
10-15-2019 07:54 PM
Your CME Router has 37.236.146.168 as ITSP facing IP Address. When I looked at the INVITE logs carefully, you were sending sip:442037752050@sip.bluetelecoms.com in FROM field instead of sip:442037752050@37.236.146.168 and same thing for P-Asserted-Identity field. Your ITSP was not authenticating FROM or P-Asserted-Identity filed using sip:442037752050@sip.bluetelecoms.com. The SIP profile changed that to sip:442037752050@37.236.146.168.
Please post your final working configuration.
10-15-2019 11:41 PM
