SIP trunking issue between ITSP and CallManager Express
Hi all,
I have an issue about sip trunk configuration with ITSP.
Here is my Topology
SIP/SCCP phones ----> CUCME/CUE router ----> Firewall -----> EdgeRouter------> Internet----------> ITSP
I have attached CME router configuration file.
I have made outgoing call from my SCCP phone with no success.
Here is debug ccsip messages output for outgoing calls:
SIP Call messages tracing is enabled
un-vr#
Jan 25 07:46:27.522: //30502/34CF873F86F4/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:096134848@81.89.216.4:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.10.2:5060;branch=z9hG4bK52C10D5
From: "Ruzanna Zohrabyan" <sip:129@81.89.216.4>;tag=1E41B6C4-1678
To: <sip:096134848@81.89.216.4>
Date: Wed, 25 Jan 2017 07:46:27 GMT
Call-ID: 36501804-E20911E6-86F98E92-7CF6C55E@192.168.10.2
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 0886015807-3792245222-2264174226-2096547166
User-Agent: Cisco-SIPGateway/IOS-15.3.3.M
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1485330387
Contact: <sip:129@192.168.10.2:5060>
Expires: 180
Allow-Events: telephone-event
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 246
v=0
o=CiscoSystemsSIP-GW-UserAgent 718 7174 IN IP4 192.168.10.2
s=SIP Call
c=IN IP4 192.168.10.2
t=0 0
m=audio 16822 RTP/AVP 0 101
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=ptime:20
Jan 25 07:46:28.022: //30502/34CF873F86F4/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 25 Jan 2017 07:46:28 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1485330388
Expires: 180
Content-Length: 246
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
Jan 25 07:46:29.022: //30502/34CF873F86F4/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Wed, 25 Jan 2017 07:46:29 GMT
Min-SE:  1800
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1485330389
Expires: 180
Content-Length: 246
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-16
a=ptime:20
When I am calling to my given number from ITSP, I hear message from provider PBX ("The number is unavailable")
but I am registered with SP:
un-vr#show sip-ua register status
Line                             peer       expires(sec) reg survival P-Associ-URI
60488111                         -1         1934         yes normal
Rajan
Hi Rozanna,
Can you confirm with the provider that the number you are sending in the Invite is correct ?
What is the reply you are getting from the provider for the invite sent. Can you provide the complete ccsip debugs to check that.From the info you provided, it seems like the provider is not accepting the number you sent in the invite and they dont know to route the call for the number sent.
Rajan
Pls rate all useful posts
Rajan
Hi Rozanna,
Rajan
Actually 129 is our local extension, it must be from 129@192.168.100.1
I don't know why it has been changed?
There is no other messages, I have pasted all output from the debug ccsip messages command.
basheerh
Hi Ruzanna,
As there is no reply back to the INVITE from ITSP (TRYING for example), this means there is no SIP messages forwarded to CME. Check firewall configurations if is forwarding incoming SIP traffic to CME either by one-to-one NATing (if you have dedicated public IP address for CME) or port forwarding (forward 5060 and UDP media).
BH
