SIP-UA calling-info pstn-to-sip from name set ABCDEFG Cannot be saved on UC560 (Uc500 series)
Simon Robert
When i go in CLI and i do this command:
Conf T
sip-ua
After that command, the Caller ID name of all my phones are the same : ABCDEFG for example.
So i do: Write mem or copy running-config startup-config
It's works, I see that the Startup-Config has the command : calling-info pstn-to-sip from name set ABCDEFG
Unfortunately : When i restart the UC560 router or a i get a power failure, the command completely disapear!!!
I don't understand why this line disapear on the running-config after a restart.
All other commands that i write on CLI are stored except this one.
Hope that you can help me.
0 Replies 0
