SIP-UA Calls and Call Legs
shawny
Hello All,
Trying to get a better understanding of what I'm seeing on our CUBE.  If I make an outbound call, I am seeing a single entry for my call when I run the show sip-ua calls brief command.  When I make an inbound call to my DID I end up see about 15+ of these entries.  My question is, Why?  Why am I getting in excess of 15 calls legs on an inbound call, and only a single one on outbound.  I've attached my dial peer configs, the outputs of the show commands, and the SIP setup.
Thank you,
how many call legs do you see when you enable 'show call active voice brief' for an inbound call?
//Suresh Please rate all the useful posts.
It gives me the same information.  About 15+ calls that are all active, between my called number and my DID.  I just tried it now and with only one other call connected (was only showing a single call leg) I am now seeing 38 sip call-legs with my  own inbound call.
can you post the output of 'show call active voice brief' pls?
My bad, should have known better.  here is a copy of both a show sip-ua call brief and show call active voice brief.  The output of this is a single inbound DID call on the system.  There was no other traffic (phone wise) at the time.
